Hello,
I am having issues getting my channel output voltages to change (1-5vdc) by manipulating the data file values. I am also curious as to my scale max. It is an existing PLC5/20e program that has unused analog outputs for some time that are now trying to be utilized for something different.
My data file block for BTW is N16:111 Length 37. So I am changing values in registrs N16:11,12,13,14 respectively for 4 output channels.
My understanding is the max scale for all votage/current outputs is 4095. My register scaling starting at bit N16:117 is 16533. I am confused by this, and is this possibly causing my issues?
Right now I have 2.8vdc on channel 0, 1vdc on channel 1, 1vdc on channel 2 and 3.5vdc on channel 3.
My values for N16:111-N16:114 are 0,0,1280,16533.
I've done this before in a previous program and everything worked fine and matched how the manual for the module explains it.
I'm missing something on this application. The rung has also been disabled some time ago by a timer that would never execute. I am testing with a test toggle bit.
Any insight/explanation for the pros would be really appreciated.
Thanks,
B
Thanks,
B
