![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Sep 2010
canīt complete integration of the WinCC flexible project on step7
hey guys,
im trying to integrate the project following this tutorial: Proceed as follows to integrate a WinCC flexible project in STEP 7. 1.Open the WinCC flexible configuration. 2.Select the menu command "Project > Integrate in STEP 7...". The "Integrate in STEP 7 projects" dialog opens. 3.Select the relevant STEP 7 project in the dialog box. If the project you desire is not listed, navigate via the search field to the folder in which the STEP 7 project is located. Integration is executed once you select the STEP 7 project. This 3 steps is ok! Now: Parameterization of the connection / communication partner In the "Stand alone" mode you have set all the connection parameters to the controller manually. In the "Integration" mode you can define the station via which the communication partner is to be addressed using the selection menu. The addresses are then transferred automatically. Furthermore, using this measure with the tags, you can access the symbolic connection. 4.Open the STEP 7 project in which you previously integrated the WinCC flexible project. OK 5.Mark the HMI station and double-click to open the "Configuration" of the HMI station.OK 6.Open the "Properties" of the operator panel's interface and define the interface and address.???????????????????? in my configuration does not appears this! attached file please any help? thanks |
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
opening WinCC project on another computer | Pandiani | LIVE PLC Questions And Answers | 5 | January 27th, 2013 03:53 PM |
Opening older project with WinCC Flexible 2008 runtime... | Syrist | LIVE PLC Questions And Answers | 2 | March 24th, 2010 04:15 PM |
WinCC and WinCC Flexible comparission | Gromit | LIVE PLC Questions And Answers | 2 | September 12th, 2009 03:16 AM |
wincc & wincc flexible differences | is_razi | LIVE PLC Questions And Answers | 1 | September 18th, 2008 11:24 PM |
WinCC project reading STEP 7 project symbol table | Pandiani | LIVE PLC Questions And Answers | 1 | August 11th, 2005 04:20 PM |
