Activation On VM
turbohamad
Jun 2009
Multan
107
Hello Friends;
I am new with Virtual Machine. I have V 10 Machine of RsLogix 5000 and my Host computer have a win 7 64 bit OS.
There are two options
1. Is there any way to install Version 10 of RSLOGIX 5000 On window 7 64 bit?
2. I f i installed a VM with Win xp Sp3 then is there any guide line to activate the software on VM?
Regards
Hello Friends;
Regards
To share an activation between host and VM:
KB QA17965
https://rockwellautomation.custhelp.com/app/answers/answer_view/a_id/493209/loc/en_US#__highlight
Rockwell really hosed their site... I tried several methods for sharing the article and none work.
Search for the number that dmroeder gave, or for an article titled "Sharing Software Activations on Virtual Machines".
You can set up a micro lan between the two. Add a Loopback test network adapter to both computers (VM and host) and set their IPs to the same range but one you don't commonly run into..
I used 172.16.31.1 and 172.16.31.2, then have your VM use the IP of the Host's Loopback adapter for its license server source. This way the VM will look at the host for its license, and it doesn't depend on you being connected to a network.
Hi Folks, who know why after start FactoryTalk activation manager V4.03, click "Get New Activations", it displays Is not I appreciate with any...
51
Rockwell Tech Support seemed to have hit a wall with this question. Already updated the version to 5.00.13 per their suggestio but am still...
208
Hello guys, I would need some help. I have installed the aveva plant scada and want to run a project. From the configurator, all are fine, as I...
97
Hello all, I have the misfortune of needing to support some old firmware version 1756 controllogix machines in rslogix 5000, as well as some...
825
I have a Win10 host that crashed this weekend. I reinstalled windows and Factorytalk Activation. Now my VM won't pull the licenses. Host and VM...
858
