plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old October 21st, 2013, 01:58 PM   #1
allscott
Canada
allscott is offline
allscott's Avatar
Bi-Coaxial Cable
I am installing some sensors from a German manufacturer that is calling for "Bi-coaxial line symmetric. Z=100ohm, maximum length 1.5M High Temperature resistant. min. 230 grd.c"
Is this what we would refer to as TwinAxial cable in North America? The closest thing I can find is a Belden part #89207.
http://www.belden.com/techdatas/english/89207.pdf
Other than a slightly different temperature rating am I missing anything?
I have some blue hose here (Belden 9463) that I would like to try temporarily for testing. The only difference I see is a 78ohm rating instead of 100ohms as well as the temperature rating. I have honestly never quite understood the difference in impedance ratings of coax cable.
http://www.belden.com/techdatas/english/9463.pdf
Thoughts? The sensors I am hooking up are basically antennas that are picking up a magnetic field.
Old October 21st, 2013, 02:36 PM   #2
FluxCap
United States
FluxCap is offline
Impedance matching is important for efficient transfer of power. An impedance mismatch will cause some or all of the signal to be reflected back to the source. It may work, but with reduced sensitivity.
Old October 21st, 2013, 03:38 PM   #3
James Mcquade
United States
James Mcquade is offline
I would call IGUS chain and cable.
its a German company and is also in the states.
regards,
james
Old October 21st, 2013, 03:59 PM   #4
mdim
Bulgaria
mdim is offline
mdim's Avatar
If only for the test you could try with 2 balun transformers. They are very useful when you want to transmit AV signal(75ohm coax) over twisted pair (100 ohm, pair of UTP or FTP)
But only for test. It is not a thing that I would let work anywhere else, but on my desk.
Old October 21st, 2013, 08:03 PM   #5
Bit_Bucket_07
United States
Bit_Bucket_07 is offline
Bit_Bucket_07's Avatar
Sounds like they're requesting coaxial cable. TwinAxial cable is twisted pair. Can't say that I've ever encountered "bi-coaxial" cable. Nor have I encountered coax with 100 Ohm impedance.
__________________
Old October 21st, 2013, 11:50 PM   #6
allscott
Canada
allscott is offline
allscott's Avatar
Quote:
According to Wiki (I know not always reliable) "Twinaxial is similar to coaxial but with two similar conductors". The Belden I listed has 100ohm rated impedance.
Old October 22nd, 2013, 03:29 AM   #7
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
According to wikipedia, bi-axial and twin-axial are not the same.
edit: On the other hand, they said "bi-coaxial" which isnt listed in wikipedia.
Why dont you eliminate any doubt by asking the germans of an example of an acceptable cable ?
__________________
Jesper
See my profile interests for Q&A
Old October 22nd, 2013, 09:08 AM   #8
allscott
Canada
allscott is offline
allscott's Avatar
I guess that is what I will do. I was trying to save a bit of money by buying it locally. Absolutely everything in this system is exhobitantly priced. However the sensors are crucial to one of our major production lines so if their is any confusion it is probably best to just get it from them.
Old October 22nd, 2013, 09:54 AM   #9
MHennel
United States
MHennel is offline
Look at Viakon they make a bicoaxial cable with the impedance specs that you require. They have a distributors in the US.
http://eng.viakon.com/Products.aspx?productId=100
Old October 22nd, 2013, 10:54 AM   #10
Bit_Bucket_07
United States
Interesting. That isn't coax. It's just twisted pair (twinaxial) cable with a braided shield. It's not really functionally different from AB blue hose.
__________________
Old October 22nd, 2013, 11:09 AM   #11
allscott
Canada
allscott is offline
allscott's Avatar
And it doesn't appear to be any different then what I originally found.
AB blue hose is 78ohm characteristic impedance. That is the only difference I can find. The 89207 is 100ohm and high temperature rated.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
OT: Cable increases resistance over time... (Mystery) Warren Boswell LIVE PLC Questions And Answers 11 May 24th, 2008 12:10 PM
Unidentifiable General Cable for DH+ Archie LIVE PLC Questions And Answers 2 January 30th, 2008 05:17 PM
Industrial Ethernet Cable For Remote I/O zmanvortex LIVE PLC Questions And Answers 8 May 19th, 2006 01:03 PM
cable pin-out rmonroe LIVE PLC Questions And Answers 1 January 22nd, 2005 12:02 AM
1747-UIC Cable Requirement Philadelphia Frank LIVE PLC Questions And Answers 8 December 4th, 2003 08:38 PM
