Developing a control system and converting pounds per min. to gallons per min.
Iant
Well since I am in America and I get the water out of an American water pipe it must be an American gallon. Ah what the ,,, since I paid for the water and I am rewriting the laws of physics it is now the Bentler Gallon.
HUMOR OFF
Thinking on it more I think it is termed the US Gallon (Gallon US).
It would have been so nice if we had just done the right thing several decades ago and switched to Metric. One gram of water = 1 cc = 1 ml all at STP of course.
Dan Bentler
Yep all cool and Mars Probes wont crash (Mtrs/Second) Feet/Sec.
Have a great day Dan
Hi
Water weighs 8.34 lbs/gal. This is at STP. There are 7.48 gal/cu.ft. SpGr. of water is 1.0 at STP. This info comes from the AWWA and is referenced when testing for certifications. I worked at a water utility for 11 years as an industrial electrician and we had to have all those certs. I know, a zombie thread, but I wanted something to do.
Multiplying by unity
1g water = 1 cm**3 water <== at 4degC and 1atm, IIRC
2.54cm = 1 in(ch)
231in**3 = 1usgal <== this used to be exact, but is still pretty close
2.20462lb = 1kg = 1000g
so
1 = 1 g cm**-3
1 = 2.54 cm in**-1
1 = 231in**3 usgal**-1
1 = .00220462 lb g**-1
multiplying 1 by 1 by 1-cubed (1) by 1:
1 = (1 g cm**-3) * (.00220462 lb g**-1) * ((2.54cm/in)**3) * (231 in**3 gal**-1)
= 1 * 2.54**3 * 231 * .00220462 lb g g**-1 cm**-3 cm**3 in**-3 in**3 usgal**-1
(g g**-1), (cm**-3 cm**3), and (in**-3 in**3) all cancel out, leaving
1 = 8.345 lb/usgal
Zombie thread, I know, but also
For example , I am taking 32 TPH *2000= 64,000 lbs an hour. I am taking 64,000 *.02 ( for 2%)and determining that 1,280 lbs of this weight is water. We make our product at about 10% moisture , so the operator would select an additional 8% of water that would be an additional 5,120 lbs of water per hour.
if 2% (water/(dirt+water)) of 64k (dirt + water) 1 1.28k water, then 62.72k (= 64k-1.28k) is dirt, so to get 10% moisture i.e. 90% dirt requires 62.72k dirt * 10%/90% (water/dirt) = 6.969k moisture, less the 1.28k moisture already there, which means 5.689k water needs to be added, so that 5.12k is off by over 11%, but the moisture content would be about 9.2% instead of 10%
jes' sayin'
Hello, guys, I have one problem and I hope you'll help me to solve it. I need to develop a control circuit: I have two switches like on the...
4,826
Good Morning , I have a lot I need to do yet on a project , and I would like to spend a little with my family . Sometimes I take work...
1,701
Hi guys, I've started using TIA portal recently having used step7 for a long time. In the old version using wincc I could start the runtime on...
11,679
Developing Communication between Energy Meter(Indigo+ Schlumberger) & SIEMENS S7-1200 Hi Members, I am Currently facing a challenge regarding...
1,488
Dear All, I wanted to know how to start developing a PLC project(Programming) from scratch, I have got the project script and IO details. how...
2,547
