VNC to PanelView Plus on different segments VIA ControlLogix
SDeGonge
Jan 2015
Austin TX
I would like to VNC to my HMI's but the only access I have is via the Ethernet modules in the CLX chassis. One of the modules is on the PLC network and the other module is on the HMI network. Is there a way to route from my PC to the HMI???
The problem is bridging between the two Ethernet modules.
Here is the path I need to take....
PC with VNC Viewer (192.168.1.200)
1756-L83E Slot 0 (192.168.1.100)
Backplane
1756-ENBT Slot 1 (175.10.1.122)
Panelview Plus ME (175.10.1.128)
Thanks for the quick reply.
I am currently using FT View Studio to access but I want to set up on another machine that does not have FT. This is so a coworker can monitor the HMI on his PC.
Hello, I have received a PanelView Plus 7 Performance (2711P-T12W22D9P series B) as a replacement for a standard PVP 7. So far I've managed to...
4,930
Hi All! Is it possible to establish any remote access on PanelView Plus 2711P-T10C4D6 (logic module 2711P-RP6)? This panel is running WinCE 4.10...
1,848
Is there a way to see if anyone is using the vnc server, on a panelview plus. I do not want the machine to be started remotely
1,650
Hello, I recently installed an **** Flexy 201 so we could monitor our PLCs (one SLC 500 and one Control Logix) remotely under a VPN. One of the...
2,338
I just updated the firmware on a PanelView Plus 6 via a VPN connection. Prior to the update the FTP and VNC servers had been enabled. Now it...
2,595
