RS-logix does not recognize a PLC ML1500
Raul
Feb 2003
Hi dear PLC Experts !!
I am sure that you are familiarized with this type of Allen Bradley PLC Micrologix 1500,
I am new with this and I am experiencing a problem trying to download a program to the PLC ML1500 1764 LSP BXB,
I have already configured the RS-232 driver with the RS-Linx software, but at the same time that the message "configuration succesful" is displayed,
also appears another message: "however RS-LINX does not recognize the processor device"
and then right in the window where the ML1500 icon should appears (next to the 00 DF1-COM1 computer icon)
is shown a question mark icon named "unrecognized device"
and it does not let me download the program...
Have you ever been in a situation like this ?? if so, please tell me what do I have to do!!!
I know this is a piece of cake to all of you !!
Your friend Raul
What version of RSLinx are you using? An outdated version might not know about the "new" ML1500 processor.
beerchug
-Eric
beerchug
-Eric
Dear Erik
Thanks for taking the time to answer my question.
I tried with RSLinx version 2.0 and also with ver 2.20, I know by now that I have to use a newer version of RSLinx...
Can you tell me how can I update my RSLinx Software Thru the internet?
do you know a web site where I can do this ??
Once again thank you Erik
Raul
kellian said:
When configuring driver do you select SLC-CH0/Micro/Panelview in the device field
Dear Kellian
Yes, I selected SLC-CHO/Micro/Panelview
Once again thank you Kellian
Your friend Raul
Re: Allen Bradley support
rsdoran said:
http://support.rockwellautomation.com/
Go there and look on left for downloads/utilities to get the latest version of RSLinx. THIS may require registering with AB to access this area of their website. RSLinx is available for free there but it is a limited version.
Thanks for your answer Rsdoran !
I'll try to update my software on these sites...
Your friend Raul
I currently have a setup in Siemens S7 using I-Device connections over PROFINET and I am trying to investigate an equivalent setup using Rockwell...
1,122
Hello, working with a test project, encountered such a problem that rslogix5000 does not see the modules, in rslinx I see them, the driver with...
852
Hello, I have trouble understanding the "Comms" part in the CPU usage pie chart showing in RSLogix Task Monitor Per the RSLogix Task Monitor...
893
Hello Friends I need to replace a Micrologix 1400 L32BWA with 1 1762-OB16. I had thought in a 1769-L30ER, 1 1769-IQ32 and 2 1769-OW16. But...
2,400
