Siemens .pdb file.
Hello i am facing a huge problem like yours. I have a battery lose on a plc , so i lost some hmi settings. The factory had an old pdb file but i am not able to open it on Tia portal. Can anyone help me convert it to tia protal?
Thank you a lot!
Hi Konstantinos.
PLC variables that are set on the HMI will not be saved in the HMI. Exception is recipe data that can be saved on the HMI.
Normally the HMI should not be affected by the PLC losing the backup battery, so recipes stored on the HMI will be retained.
So it does not make sense to migrate the HMI because the PLC lost battery power.
118
134
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
297
109
Hi everyone hope you'll well. Is it possible for me to download a Crack version of tia portal v13..sorry to say this but the software is very...
198
