How to change phase lage at 90 degree of PWM output
monikmodi33
Aug 2015
Ahmedabad
Dear all,
I am doing project on Kerb paving, in which there are 2 solenoid valve based on PWM output.
So, main logic like, 1st PWM output based on a 30 degree rotary sensor giving a duty cycle from 30% to 70% at that same time the 2nd PWM output giving a duty cycle from 70% to 30%. Both PWM output working as a vise versa duty cycle and have to operate servo valve based on that.
But , my main concern is that I've to use both output at 90 degree phase lagging and now the PLC output giving same PWM waveform and not on invert phase lagging.
SO, what should I've to do for that??🙃 Please give any suggestion if it's possible from software side or from electrical wiring through..any else..
I had to look up what kerb paving is - never heard of it.
You're probably not getting any responses because it's very difficult to determine what you are asking.
Which PLC are you working with? Is there something doing this now or do you not have any hardware yet? Show us what you have done so far.
It is so very vague what's going on here.
You have a 30 degree rotary sensor - driven by what? Why is there a rotary sensor and why is it a "30 degree rotary sensor"?
And you want one solenoid PWM duty cycle inverse to the other such that one is increasing while the other is decreasing?
sounds like quadrature
now I'm somewhat lost - what is "invert phase lagging"? Maybe you could draw something simple in Paint or something else.
Again, what have you done so far?
And, is this a student exercise by chance?
Logix Controllers S:FS relation to Phase Manager "IDLE" State change on power up Alright, I've got an interesting scenario. I am using...
3,077
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
157
Greetings I have a problem, my system is the following: wincc v8.0 (demo), logo8.3, abb m2m analyzer. I created some pages to display the...
53
We had one go down. we have a new one. Their emergency Number don't work. The Model is TLSA046AAH-330N01-007 A catalog says we need software TET...
165
“The HMI files we cannot open—they were saved in V13—we do not have that—I cannot restore file –please have them save in V11 and send them back to...
171
