saeqsae Member S Join Date Jul 2019 Location Concepcion Posts 45 Oct 30, 2019 #1 Hi all, i have a little issue with FTV. When i open a display using parameters, and want to show different literal strings with that parameters, the software put this strings on quotation marks and i need to remove those quotation marks. There is an easy way to do that? Image related.
jkerekes Member Join Date Aug 2007 Location NJ Posts 2,362 Oct 30, 2019 #2 You need to make the strings without normal spaces. You need to use a character that isn't visible. Use the Alt + Numeric Pad number to insert.
saeqsae Member OP S Join Date Jul 2019 Location Concepcion Posts 45 Oct 30, 2019 #3 Thanks for your help. What is the combination? I tried with ALT + 32 but, the quotation marks stills on.
saeqsae Member OP S Join Date Jul 2019 Location Concepcion Posts 45 Oct 30, 2019 #4 It was ALT+255, Thanks jkerekes. Regards
jkerekes Member Join Date Aug 2007 Location NJ Posts 2,362 Oct 30, 2019 #5 Yeah, I forgot too and didn't have a VM open.
