FTV SE Historical Alarms
JonAW
Sep 2013
Somewhere
121
Hi All,
I am experiencing a problem with FTV SE historical alarms.
I am using the Almd control from several Compactlogix L3 processors to talk to the alarm & events server on my FTV SE V8.1. I can't seem to be able to point the almd so the historical database records the alarm. The alarm is showing on the alarm & events alarm banner but once acknowledges is no longer available to view. The only way I could record to the database was to setup another Bool and trigger the alarm from the HMI basically double the work for 700 odd alarms. This has flagged up even more complications however if I could get a solution to recording the alarms directly from the almd block activation to the historical database then I would have a complete solution.
Does anyone have any ideas?
Thanks in advance
Jonny
Hello everyone, I am currently working on a project that uses a Rockwell L33ER controller and the FTV Studio V13 as Supervisory computer...
128
Hello everyone, I am working in a platform and we installed FTV CLIENT SE V 12 IN ALL THE CLIENTS COMPUTERS, we have 6 clients and only 1 is not...
98
Hi all, I'm having difficulties trying to connect FactoryTalk View SE Local Station (V13.00) to MS SQL Server Express. I state that they are...
131
Hi to all, Does TIA portal support creating reusable pop-up display as FTV has it implemented? Something like on link below. Thanks in advance.
530
Hi all, I have a question about the communication from the FTV and the PLC for different machine I use. Most of these use a SLC5/04 PLC and...
293
