Calling Password Prompt/Popup in FT View SE v7/v9
RVaughan
Mar 2012
Michigan
177
Current project requires most HMI screens to be locked out without user login. I set the appropriate security code on each display, so now the Goto Display buttons don't function without login. Instead of nothing happening, I'd like to show either a Login Required message popup or a login prompt. How do I make this happen?
I can use the [Diagnostics] popup, but its log includes other prompts and information that the customer doesn't need to bother with and would prefer not to see. Can I restrict it to user access messages only?
I can also make the Goto buttons invisible or change color based on user access level, but I'm hoping there is a less tedious method (30 +/- buttons).
I went ahead and changed the visibility on the Goto buttons. The screen connection web wasn't as complicated as I expected.
This is the first time I am working with Simatic Manager Step7 as I started my siemens journey with TIA which is pretty easy and do a lot of stuff...
142
I am looking to get an AB series 1774 (PLC1) from the 1970's up and running. I have all the parts, and it powers up just fine without errors if I...
2,321
Hello all, I’ve recently begun using Automation Studio on my own time to boost my knowledge of controllers beyond AB/Siemens. To ease myself into...
899
Hello I'm new to PLC programming and I'm programing in ST. Programming envirement is GX works 3. I can't figure out how to jump to subprogram or...
1,460
I have some code i need to block until a super genie for data entry has completed (by operator input)as per below. FUNCTION New_Setpoint()...
2,274
