plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old August 11th, 2007, 03:50 AM   #1
PLC_talk
India
PLC_talk is offline
How to set tuning constants for SLC PID loop
Hello,
I am using a AB SLC5/05 PLC & using the PID insrtuction for a single loop control. I have assigned N10:0 as the control block starting address, so I beleive the Kp,Ti,Td will be N10:3,N1-:4,N10:5 resp.
Question - The tuning constant are in decimal values where as the Integer file N10:x will not accept decimal. So how do I send the decimal constant to the PID instruction from the graphics screen?
Any pointer or solutions in right direction will be helpful.
Thanks,
Old August 11th, 2007, 05:54 AM   #2
Drippin
United Kingdom
Drippin is offline
Maybe helpful.......
Are you entering values from an HMI? If not, you should just be able to double-click on the PID instruction "Setup Screen" and enter the values directly - here it would not matter if they were decimal fractions or integers.
If you are using an HMI to enter Kc, Ti and Td, well I'm not too sure about this as I have never done in SLC500 (PLC5 used Floating Point files and relabelled them in the file structure e.g. F18:0 becomes PD18:0). Looking at some software we use here it appears that the SLC500 performs a floating point-to-integer conversion if FP vales are enetered via a MOV instruction. Why not try entering some "dummy" code at the end of a running program to see how the PID instruction handles moved FP values?
Hope this is (a little bit) helpful!
Dave
Old August 11th, 2007, 10:14 AM   #3
Mickey
United States
Mickey is offline
Mickey's Avatar
See links below. The values you write to the integers will have to be an implied decimal. The PID instruction has build in multipliers.
http://www.plctalk.net/qanda/showthr...ghlight=RG+bit
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old August 13th, 2007, 08:25 AM   #4
PLC_talk
India
PLC_talk is offline
Smile
Mikey,
Thanks, you were spot on
It solves my problem.
Regards
Old August 13th, 2007, 09:41 AM   #5
Mickey
United States
Mickey is offline
Mickey's Avatar
Your welcome
__________________
Mickey
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
PID Loop TI505 (TISOFT) karivelm LIVE PLC Questions And Answers 6 November 21st, 2006 01:56 PM
PID Loop question tgaljar LIVE PLC Questions And Answers 13 June 14th, 2006 08:46 AM
PID loop dimented LIVE PLC Questions And Answers 1 May 16th, 2006 05:43 PM
Trying to find a website ganutenator LIVE PLC Questions And Answers 9 January 5th, 2003 04:06 PM
