Hello
Thanks for your responses.
The process is a treatment water system. It consists of 24 steps. I am replacing a old sequencer device.
Enable timer should be "always on". I am using TONR because sometimes the process should stop in some step.
The Jump_Step_PB is because in some step it could finish before time is reached.
I am a novice with Siemens, my main experience is with AB.
I am considering all your comments.
I have a HMI_Data FC2 block, I use to introduce from HMI values to the timers and show the elapsed time, so I have created the attached network.
As i said, i need 24 timers, so I am repeating this Network 24 times...
I am considering to use FB block, and I have tried the first 3 timers as FB block, but each time that I use this FB block, a DB file would be created? So, I would have 24 DB for this FB block? I am reducing network in the FC block but I am adding DB to the main project.
or I am doing something wrong?
Thanks for your suggestions.
