Modbus RTU redundancy
Hi guys:
After we got the price for this interface box (Controlinc) the customer decided for a new approach . He wanted to make a ring out of modbus RTU (Redundant), I read lots of manuals and web pages to finally find out that this is not feasible.
The only way you can setup some kind of redundancy using modbus RTU is to use in my case valves with two modbus rtu interfaces and use two modbus rtu modules on the PLC one module for each modbus interface. Which means that we two independent modbus rtu networks not a ring.
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
46
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
221
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
252
Hi, I'm having an issue with a mircologix not transmitting out. The current setup is a mircologix 1400 connected to a Guardian 100 Radio...
109
If a device has Modbus RTU over serial and Modbus RTO over TCP and Modbus TCP then there is a difference between Modbus RTU over TCP vs Modbus TCP...
478
