FTVIEW SE client display the value from MSSQL server using VBA Code
kmrengan
Apr 2019
Hello Every one,
I need a help on vba code for getting data from MSSQL server 2014 to display in FTview SE client version 12 . Thanks.
Please support on this.
I have tried the below code:
Sub ConnectSqlServer()
Dim conn As ADODB.Connection
Dim rs As ADODB.Recordset
Dim sConnString As String
' Create the connection string.
sConnString = "Provider=SQLOLEDB;Data Source=DESKTOP-HSKPA00;" & _
"Initial Catalog=MondelezDB;" & _
"Integrated Security=true;"
' Create the Connection and Recordset objects.
Set conn = New ADODB.Connection
' Open the connection and execute.
conn.Open sConnString
Set rs = conn.Execute("Select AVG(val) from dbo.FloatTable where TagIndex=5;")
' Close the recordset
rs.Close
conn.Close
Set conn = Nothing
Set rs = Nothing
End Sub
in sConnString you may need to add the user and password for the database.
Here is one I use:
"Provider=SQLOLEDB;Data Source=192.168.1.250;Initial Catalog=CIPLog;UID=plant;PWD=plant;"
Private Sub Update_Trend_Press()
Dim ConnStatus As Boolean
Dim strStatement As String
Dim AVGTestTag As Tag
On Error GoTo ErrHandler
' SQL Script For Data Average
strStatement = "Select AVG(val) as AVGTestTag from dbo.FloatTable where TagIndex=5;"
Call SQL_Connection(strStatement, ConnStatus)
Set AVGTestTag = TagDB.GetTag("TestTag")
TrendPro1.Refresh
End
Exit Sub
ErrHandler:
MsgBox "VBA Error: Display (" & Me.Name & " - Sub Update_Trend_Pressed) - " & Hex(Err.Number) & " - " & Err.Description, ftDiagSeverityError
Application.LogDiagnosticsMessage "VBA Error: Display (" & Me.Name & " - Sub Update_Trend_Pressed) - " & Hex(Err.Number) & " - " & Err.Description, ftDiagSeverityError
End Sub
' SQL Connection Details
Private Function SQL_Connection(Query As String, ConnStatus As Boolean)
Const strConnection As String = "Provider=SQLOLEDB;" _
& "Server=DESKTOP-HSKPA00;" _
& "Database=MondelezDB;" _
& "Uid=ENPLLC;" _
& "Pwd=ENPllc123;"
Dim objCon As New ADODB.Connection
Dim objCom As New ADODB.Command
Dim SQL_Conn_Alarm As Tag
Dim objrs As New ADODB.Recordset
'Indentify the database being used.
objCon.ConnectionString = strConnection
'Open the connection.
objCon.Open objCon.ConnectionString
'Execute the statement.
If objCon.State Then
strStatement = Query
With objCom
.CommandText = strStatement
.CommandType = adCmdText
.ActiveConnection = objCon
.Execute
End With
End If
ConnStatus = objCon.State
'Close the connection.
objCon.Close
Application.LogDiagnosticsMessage ("Database connection closed at " & "" & Now & "")
'clean up
Set objCom = Nothing
Set objCon = Nothing
'End
Exit Function
End Function
First time using SE and I'm stumped on this one. I've developed my app, tested it within Studio to a live PLC, I have a valid license. Running...
3,165
Hi guys Merry Christmas to all of you here. I am currently having the problem as per title. My system consist of 2 redundant server and 3...
4,130
I am working at a remote site that has a FTView SE system that has been running for years...V9. About an hour ago the operators called me over...
674
Hi, We develop a small application in ftview se. It runs fine on the laptop were we have studio, communicates with the plc etc etc. Now we...
1,440
Waterproof Industrial 3.5mm Speaker for use with ThinClient and FTView Alarm&Events Hello, Elsewhere at this site the thinclients (Dynics BTMM)...
874
