Mitsubishi PLC : How to enable hidden ladder
zai_jnr
May 2008
MALAYSIA
169
Dear all,
I'm now working with Mitsubishi PLC Q02 H..got trouble to view hidden ladder..Here I attach the programming..
In Main Section at step 1563..the ladder is hidden..how need to view this ladder? Really need your help...:confused:
Thanks a lot
The yellow section is not hidden ladder - it means that there has been a conversion error.
issue settle..that not because of conversion error...
need to set view contact from 9 to 12 contact...then can see the hidden ladder..
anyway...thanx for the reply....
The wrong contact setting would be one of the things mitsi considers a conversion error.
This happens if the program was written in GXIEC & uploaded with GX, the code is not always translatable into ladder although as far as GX Developer is concerned there is an error the logic actually works.
However looking at the code this does not look like GXIEC the other possibillities are that it was written in a different program or the engineer deliberately did it to confuse, I have loaded it into GX Simulator & it goes into run mode so no problems with checksum, if you look at it in stl you can see the code & with a bit of thought you may be able to understand what the logic is & re-write it so it displays in ladder.
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
I have Toyopuc PLC PC10G-CPU and some communication modules of it. With this modules I'm able to connect with Ethernet, Ethernet/IP, FLnet, FRMT...
88
Hi all, anyone does have experience in Gx Works 2? Currently I having an issue which is when certain device added from MELSOFT Navigator and...
110
Hi All, I am after some assistance setting up kepware to take tag data from an FX5U PLC, I have tried many many port numbers and still cant get a...
157
