plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Unread October 4th, 2019, 11:03 AM   #1
strantor
United States
strantor is offline
Most complex PLC program?
What application in your experience has demanded the most complex PLC program?
I suppose I should clarify what manner "complex" I'm asking about. So a PLC with 10,000 I/O controlling a few thousand valves all in the exact same way, with the same 4 or 5 rungs of code copied/pasted a few thousand times, is not what I picture when I think of complex. When I think of complex, I picture a few thousand rungs* of (for the most part) unique code, each rung* (for the most part) having required deliberate thought by someone with vast knowledge and above average cranial processing power.
Palletizers stand out in my mind as being usually pretty complex
*rungs, may be substituted for lines of ST or whatever. Not necessarily ladder.
Unread October 4th, 2019, 11:37 AM   #2
jstolaruk
United States
jstolaruk is offline
Palletizing is usually pretty straight forward, same logic just different heights.
A few that come to mind: a transmission test line with multiple unique test stations, a operator "guided" automotive instrument panel installation servo arm that tracked the vehicle as it started and stopped going down the line, and a robot cell that featured 5 robots that interacted together to install camshaft bearings.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Unread October 4th, 2019, 11:55 AM   #3
James Mcquade
United States
James Mcquade is offline
several things come to my mind.
oem test equipment such as electric car seat testers, fatigue testers, assembly line equipment.
I did a seat track program with 10 stations that had 2400 rungs.
automotive assembly lines.
james
Unread October 4th, 2019, 11:56 AM   #4
dahnuguy
United States
dahnuguy is offline
Automotive body shop.
Couple hundred PLCs, conveyors, bunch of robots, welding, riveting, material handling, different model being made on every unit, possibly over 30 models made on the same line.
Each model different robot paths parts data, options, all feed from a plant system sending list of units to make.
Add to this all the material delivered to the line, operator loading stations, safeties, over 50,000 alarms per station of which there are over 100 stations.
The look aheads and data collection for quality...
And all this making a unit every 70 to 90 seconds all day everyday sometimes 24/7.
Now develop all that machinery in a 3 to 6 months and do the install in 9 weeks.
And that's just to make the metal shell of the body.
Unread October 4th, 2019, 01:27 PM   #5
Peter Nachtwey
United States
Peter Nachtwey is offline
Peter Nachtwey's Avatar
dahnuguy has a good example but it is just big.
I can think of veneer lathes or lumber mills mostly because of the gearing, speed, precision, and non-linear motion. Auto factories may make many types of cars but no tree is the same.
__________________
"Living is easy with eyes closed, misunderstanding all you see...." Strawberry Fields Forever, John Lennon
Unread October 4th, 2019, 02:12 PM   #6
saultgeorge
United States
saultgeorge is offline
I wrote one for a hybrid test cell. It allowed temperature extremes from -40 to 140 F, a de-humidifier unit with 2 burners, 4 cooling/heating valves, another climate control unit with just heat, 6 sets of fans, a pop-up cooler, heat recovery system. The temp extremes had to increment 10 degrees per hour under a 30 degree temp and 20 degrees per hour above 30 degrees. 1 main controller, 2 remote racks. Also damper controls. About 14 PID loops. Probably not too complex, but very diversified.
__________________
4 out of 5 Great Lakes prefer Michigan.
Unread October 4th, 2019, 03:34 PM   #7
JaxGTO
United States
JaxGTO is offline
Programmed an air bag inflator line using a AB PLC-5/250 Pyramid Integrator with a VAX module. 25 pick and places, indexing conveyor, RFID tracking, 12 PanelViews, 4 welding robots and barcode readers at each station using the old RB modules.
__________________
I have to use Rockwell Software!
Unread October 5th, 2019, 05:29 AM   #8
dahnuguy
United States
dahnuguy is offline
Each car is different and has around 100 different details for each model. The data being transferred from every fixture to every robot and down the line. While looking ahead to get the next car data and the one 3 or 4 up the line to process offline sub-assemblies so they are all ready when the pallet arrives.
The shear quantity of tags and faults and feedback and data storage is amazing.
The speed and volume of information being handled is just one issue.
The fault recovery allows the line to recover from faults in less than 5 minutes on average.
The number of remote I/O and subsystems and different components all being coordinated all working at the same time is more than I have seen anywhere. More than I can imagine being used in any process.
Linear motion while picking parts from a stack or pallet or rack where each part is located by machine vision and offsets calculated on the fly and parts count to flag resupply...at hundreds of locations.
Machine vision for placing glass and roofs, laser welding while using machine vision to locate and control the weld path...Stop and think about that one for a second.
It is the magnitude of all this that becomes complex. No one part is all that bad when you zoom in.
Now imagine you are cutting 1000 trees all at once and each one fits into the next... every minute, and keep up with where each one came from and then track every piece of wood from beginning all the way to Lowe's.
Or
Receive tree... rotate tree and move one cutter into it based on a feedback loop, drop the core, open the gate...
Repeat.
As interesting as it is, I don't see a couple tuned loops in a serial process of conveyors and cutters as being terribly complex over all.
You left out car washes...
Unread October 5th, 2019, 05:37 AM   #9
dahnuguy
United States
dahnuguy is offline
Quote:
I have seen machine vision palletizers that were more than just pick and place and move to next level.
Imagine picking from random parts in any orientation then sorting on the fly to determine the place location while in route to one of several locations, then stack.
Unread October 5th, 2019, 05:40 AM   #10
dahnuguy
United States
dahnuguy is offline
Really nothing we do is terribly "complex" when you break it down.
Unread October 5th, 2019, 06:37 AM   #11
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Quote:
Dont tell anyone.... they still think im a genius
Anything with motion and speed has been the hardest to grasp just because it can be so fast you cant see it happen you just have to trust that it happened and move on. Big is also complex just because you can have so many moving parts that work together and it takes a long time to fully understand the system if you did not build it.
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, Fluke Meters, MicroLogix, ControlLogix, Siemens, Allen Bradley and more... all your automation needs... ((NEW)) After Market 1784-U2DHP Allen Bradley USB to DH+ and Gateways
Unread October 5th, 2019, 07:13 AM   #12
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
I always wanted to get the opportunity to get into the UPS air distribution center in Louisville, KY or FedEx's in Memphis, TN. I was at a hotel next to the Louisville airport and could not count the UPS jets landing there were so many, the number of daily packages would be impressive.
All those conveyors tied together with hundreds of discharge points, multi-level storage, package tracking (in, out & moves), logging, etc. Those must be some pretty complex systems.
__________________
Never underestimate the quality of idiots that will be running your machines
http://aabeck.com
Unread October 5th, 2019, 07:51 AM   #13
lfe
France
lfe is offline
I recently visited the Amazon logistics center in Barcelona, 150,000 square meters, 60,000 mobile shelves moved by 10,000 robots, countless belt conveyors,
I guess the automation would be mainly AB, the electrical cabinets only had a display that indicated the supply voltages, but without any HMI screen.
__________________
Suppanel HMI
Unread October 5th, 2019, 08:01 AM   #14
jstolaruk
United States
I have and the ability to pick randomly oriented parts off a moving conveyor has been a standard feature of robots with vision for a while now ( I just finished one last week). It's still cool to watch even after doing about a dozen of these.
__________________
Unread October 5th, 2019, 10:48 AM   #15
ganutenator
United States
ganutenator is offline
ganutenator's Avatar
I know it doesn't sound like it should be, but I have been writing plc and hmi programs since 1997, and this inbay automatic car wash has been by far, the most difficult piece of equipment that I have ever had to program.
I think mostly, it is because people are involved. And people do the craziest things.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Mitsubishi:Problem with downloading program to Q PLC anhtuandrg LIVE PLC Questions And Answers 0 December 18th, 2015 11:48 PM
How to know that PLC Program is Re-downloaded ? nilesh_1106 LIVE PLC Questions And Answers 12 July 17th, 2015 11:53 AM
Call PC program from PLC and return results from PC to PLC adavi231 LIVE PLC Questions And Answers 7 April 12th, 2012 04:30 PM
Mitsubishi GX Developer - uploading/downloading program from PLC mkac LIVE PLC Questions And Answers 7 June 17th, 2010 04:31 AM
PLC Simulation Program mmarch LIVE PLC Questions And Answers 6 May 24th, 2007 09:30 PM
