Micrologix communication with BX printer using RS 232 port
mona
Dec 2010
maharshtra
I want to read the data from printer as well write the data from plc to printer.
Is there any special data format is required to write the data?
If I want to write 10 number to Priter for saying that my plc program is ready, then what should i do?
If my using ASCII instructions
what are the steps to send the data to printer?
& how I read the data coming from printer?
is it just ASCII to integer conversion required for reading the data
please help ASAP.
Hi all, I had a setup with 2 Micrologix 1100 connected to a Panelview C300 over DH-485. I was mandated to upgrade the HMI, and proposed to...
889
Hello, I'm working on a project in which I need to communicate a Micrologix 1400 series C to a Zebra printer ZD230t through Ethernet/IP. Is there...
749
Having an issue with network timing out when trying to use CIP generic on a Micrologix 1100 B. I’m trying to read flow and totalizer information...
19
5,020
Hi! Last few I've been trying to send message from MicroLogix 1400 to Micro 850. Unfortunately every time I failed :banghead:. Did someone tried...
3,191
I been tasked with setting up communication between a heating cooling unit manufactured by Advantage Engineering and a Microloagix 1400 plc. The...
2,513
