Can View Tags on One Version of 5000 but not the other Version
showshocka
Mar 2011
USA
510
Hello. Please view theses screen shots of a logix 5000 project, the same file on two different shop laptops. Version 19 shows no tags, version 17 which is an earlier version shows all my tags. What's going on and how can I get the tags to be viewed in Version 19 also?
I cannot see your Scope in the first picture. Second picture says LINE_3_AUTOOP
Make sure you are looking in the same Scope for your tags.
What I'm seeing in your two pictures is you have 'tags' in both. What you don't have from one to the other are 'descriptions'. Those ARE NOT stored in the PLC whereas the 'tags' are. Could that be the case? One of them is just an upload from the PLC whereas the other also has the original source project on the computer to access the 'descriptions'.
This is the same one file that I have on a stick drive. it shows more tag descriptions in version 17 than 19. one computer has version 19 installed and one computer has only version 17 installed. the earlier version shows more in the controller tags tab window than the other, which the version should not matter. its just what I noticed. here is again the same one file from the stick drive and a screen shot from each laptop.
The picture's a little fuzzy but in 'versionb.jpg' it looks like you're filtering on the letter 'J'.
In the picture in your first post it's filtered on the tagname and showing tags containing the letter 'J' and in the picture in your last post it's filtered on the description, so it shows descriptions containing the letter 'J'.
I just migrated a rsview32 project which worked relatively well, just a few bugs. There are places within that used system\alarmmostrecenttagdesc...
1,161
Hi all, I have used your forum a lot in the past for helpful hints, but I could not find anything on this question. I have a project where I am...
2,855
Hi All, we've recently upgraded from FTView SE v10 to v12. Since the upgrade we've been having a problem where the HMI is slow to update tags in...
87
Hello all. Is there a way to upload alarm tags at the bit level to my FTView studio? I export them from my PLC thinking I will upload them to...
408
Hello all. I am trying to establish my connections in FTView Studio. Normally, after I have set up my offline tag file in communication setup I...
654
