KFD32 Error: Initialization Failed
mccecim
Apr 2010
Belem
24
I have a SLC 5/05 and a DNET Scanner (1747-SDN) to communicate to my other devices on a DeviceNet Network. The Linx driver is already configured and baud rate, COM port checked. I'm trying to go online on DeviceNet network trought 1770-KFD and a USB-Serial converter (the converter is working well) but when I try to go online I have the error:
KFD32 error: Initialization failed.
Is someone could suggest what can I do to solve the problem?
What is the behaviour of the LEDs, the lamp indicators of the 1770-KFD?
It seems you may be having problems in the RS232C side.
Many USB to RS232C converters do not work with legacy RS232C devices. One way to see if the initialization problem is related to RS232C communication is to use a desktop PC with a COM port build-in the mother board and see if the tool can initialize the 1770-KFD, If you do not get the "Initialization Failed" error on the desktop, the problem is likely in the USB-serial converter. If you also get the same error on the desktop, the this suggests the serial cable you are using has a problem.
Agreed; the cable for the 1770-KFD requires those jumpers. You can use a cable from the -KFD for ordinary SLC serial ports, but you can't use the ordinary SLC serial port cable (1747-CP3 or equivalent) on a 1770-KFD.
I have generally had good luck using USB/RS232 converters with the 1770-KFD, but I mostly use the reliable Keyspan USA-19HS.
Hello Everyone, I have a issue with communication between two different PLCs. So here is the facts, The Master PLC is Guard Logix 5069 with IP...
72
Hi Siemens guys! I am experiencing SF fault on our S7-300 (6ES7 315-2AH14-0AB0) CPU from time to time. I've checked the diagnostic buffer and...
169
Hello..I am new to Plc.I have Mitsubishi Melsec Fx3Ga-40MR PLC controlling a machine for packing powder.Currently the Plc has issue which power...
139
hello, I'm a student and for my final grade I have to repare a sepro robot. the only problem I have for now is that i have an error code 3...
35
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
46
