Brain and Google are failing me on this adapters name
dripdry
May 2016
Ohio
23
Back in the old days of ProfiBUS, I used to use this little adapter card that plugged into my laptop, it was like a compact flash card but taller on the computer end, and 9 pin ProfiBUS sub d on the other end.
Anyone have one of these or can point me in the right direction for one? I swear it had a cf card look on one end and female ProfiBUS on the other. It was pretty small.
PCMCIA was a laptop spec expansion card that had a single card capability but single or double deck to have the ports inside the laptop space if the designer so desired.
Express card never really took off due to USB.
Maybe it was a Siemens CP5511 or CP5512 card. Both are PCMCIA cards.
I used to have a CP5511, but when we changed from XP to Win7 I stopped using it. I think it is a problem with both hardware and Windows support - no 64 bit as far as I remember. And not possible to connect to a VM either.
What are you wanting to do exactly ?
Programming via Profibus. If so, which PLC ?
Connecting a PC to IO via Profibus ? If so, what is the software interface that you intend to use, OPC DA ? OPC UA ? Proprietary driver ? Or .. ?
Or .. ?
I'm event AV Technician (Sound, Projection, and Lighting). Over the last couple of years I've used a Weigl ProCommander PHX to control some event...
2,694
Hello, I have some EVAP units that use an an OPTO 22 SNAP-PAC-EB2 Brain to control I/O. I downloaded the latest basic software package from OPTO...
1,703
Hi Group See the photo. Will this work? I previously had the "contactor outputs used as inputs" tied directly to the IO DIG OUT coils, and what...
1,934
Guys(and gals) I'm stumped on this one. Below is the text of a rung that seems to defy logic. Datatypes for Label_ID and Label_ID_Loaded are...
2,357
Hi all, having a brain fade moment. I need your help. I have a inverter duty SEW 6 terminal 230V delta / 400V star motor here wired to a Danfoss...
2,305
