PCS 7 410E REDUNDANCY CPU with Comfort panel TP900
liyao1017
Mar 2016
Singapore
410E with TP900 different IP range
I have a PCS 7 410E REDUNDANCY CPU connected to the TP900 panel, from CPU side the X8 port address is configured as 192.168.11.25 (master) and 192.168.12.25 (slave), but the HMI port address is 192.168.11.28. the CPU address is fixed that not allowed to change, with the different IP address the TP900 only can communicate with master CPU and loose the redundancy with the slave CPU. Any chance to solve this issue :confused:
Hi, What is the easiest way to create a Watchdog between 2pcs S7-1200 over Ethernet?
1,511
I am experimenting with a very simple program for testing purposes and not getting any movement from the servo motor. The attached program...
1,790
I dont have connection with this panel. Please help me. Can anybody worked for whis panel? I try connect the rs232-usb cable on the foto, but...
1,142
Hi, I have a question about Siemens ET200M series modules. These will be used in a remote IO panel. In this panel will be a dual redundant Siemens...
1,326
Hello: Question for SCADA/HMI experts. One of our customers is responsible for planning and selection of key technologies for manufacturing...
2,955
