xetrov123
So the system we have is a Allen Bradley micrologix 1500 and is currently communicating over DH485 (COM 0) to a PV1000 touchscreen through an AIC.
I have a Datalink (Equustek) DL3500 DH485-ASCII that I want to use to communicate to the display. The display communicates over RS232 ASCII.
I have set the device ID of the DL3500 to "5"
The problem I believe I am running into is the configuration of the MSG command.
I have the following config:
MSG File: MG9:1
Channel: 0
Communication Command: 485CIF Write
Data Table Address: ST10:0
Size in Elements: 1
Message Timeout: 5
Data Table Offset: 0
Local Bridge Addr: 0
Local/Remote: Remote
Remote Station Address: 5
Remote Bridge Link ID: 0
The error I am getting is:
Error Code (Hex):7
Target node does not respond DF1 - DLE ACK/NAC timeout and
DLE ENQ transmitted (ENQ retries exhausted)
Thanks in advance for the help!
Chris
MSG File: MG9:1
Channel: 0
Size in Elements: 1
Message Timeout: 5
Error Code (Hex):7
Chris
