Can CompactLogix MSG to MicroLogix with 3rd octet being different?
BachPhi
Dec 2007
Los Alamos
640
I do not have the needed PLCs to test this out, wondering if this is possible?
Given CMPLX is 192.168.10.1 with subnet Mask 255.255.0.0
and
MicroLogix 192.168.30.1 subnet 255.255.0.0
Can Compactlogix MSG to Micrologix?
Yes
Yes, Your subnet mask of 255.255.0.0 opens it way up. In theory 192.168.0-254.0-254 would all be able to connect to each other. I believe that would be 254 subnets, with a total of 65534 hosts. I have heard this referred referred to as "supernetting" rather than subnetting.
and
Since the third octets are less then 63. The masks can be 255.255.192.0
Both are on the same 192.168.x.x network so no problems. If the subnets had been different comms would have only worked in one direction from the larger to smaller subnet.
Hi all I'm trying to setup a MSG connection (which I'm not familiar to) between a CompactLogix CPU (L310ER) and a Micrologix 1400 CPU. At the...
807
Hi Guys, Currently trying to read an int from a MicroLogix 1100 with a CompactLogix L16ER using the MSG instruction. It's setup in the L16ER...
4,186
Hello All, I have a total of (8) prox switches that I am monitoring (1 for each machine) with a single MicroLogix 1100 controller. I have (8)...
5,247
Hey, I'm trying to send read and write msg instructions from a MicroLogix 1400 PLC to CompactLogix PLC. In the message file instruction settings...
12,511
I am trying to set up a MSG read in a Micrologix 1500 LRP series C to read data from a Compactlogix L32E via a NET ENI series D. I have...
8,495
