Kinetix Motion
the_msp
May 2008
Northern Ireland
1,271
I am looking at getting some motion gear for R&D purposes. I have an L18ERM on order already which will be flashed to V30.
Servo drive wise, I'll likely buy something like Kinetix 350 2097-V31PR0-LM, 2nd hand. Being 2nd hand, it might not have the connectors on it so I will add:
2097-CONN1
Includes AC input power (IPD), back-up power (CPD), shunt and DC bus (BC), motor power (MP),
and safe-off (STO) replacement connectors for Kinetix 300/350 drives.
Motor wise I was browsing the AB site and not much the wiser. The VP series "are optimized to run with the Kinetix 5500 and 5700 servo drives" - optimized or exclusively for?
If I know the frame size, where do I go next... do I have to use an AB branded motor?
I am fairly certain the VP series motors are exclusive to the K5000 series drives. The VP series motors have 2-wire DSL feedback which the K350 cannot support. I haven't come across a DSL to Hiperface converter.
If you are looking to go real small loot at the TL series motors. They are the smallest and lowest cost offering you will find but I think they are all 230V motors.
It may be possible to operate a 3rd party motor on a K350 but I have never done it.
Keith
I believe the connector on the K350 side is field wireable. As long as the motor feedback is something the K350 can handle I don't think the connector makes a difference.
Keith
Everyone, I am having an issue with our current program and need advice. Our current setup has 4 servos running on a pusher chain conveyor. The...
475
Hello everyone, Ho do I go about making changes to a "Motion Axis Parameter" e.g. PositionScalingNumerator that is currently grayed out in the...
1,370
Hi All, the drive was changed recently and now having issues with the servo where it acts a bit strange. I know I need perform an auto tune. I...
1,586
I have two 2198-P070 bus power supplies for that I’m using for four Kinetix drives, 2 drives per power supply, all controlled by one processor...
1,423
Hi all, I wanted to share with you an issue that I had with a Kinetix 5500 servo drive. There was a mechanical problem with the axis, and...
2,850
