Anyone can recommend some Remote IO systems with Intrinsically Safe Modules??
cardosocea
Nov 2016
Fields of corn
2,634
I had a chat today with a contractor and he notified me that Rockwell will stop producing the Flex Ex IO modules from December 31st.
The ones we have installed are ControlNet based and I was wondering if any of you have any idea of a manufacturer that has something similar to be replaced without having to move to Ethernet?
With Ethernet connection I suppose (without confirming) that Rockwell would be a possibility as is Pepperl+Fuchs and Wago.
The PLC we have with these networks are Control Logix. Not sure on the exact processor though.
B&R's X20 IO has a wide array of bus controllers, unfortunately they don't do ControlNet (they do DeviceNet though).
EDIT: All B&R X20 (coated and uncoated) and X67 IO are Intrinsically safe. They typically do Ethernet/IP faster than Rockwell's own stuff and are always less expensive.
Thanks for confirming my suspicions. I suppose a network revamp will be in order then.
One other (more or less related) question I have is that I cannot find the product lifecycle chart (??) or timeline in Rockwell's website. Siemens, after a bit of digging usually has a page per part number displaying the launch, maturity, obsolete and discontinuation dates. Is there any of the sort for Rockwell online?
Hi everyone. I would like to know what are some brands you have had good experience with and what to stay away from. And do you have any...
3,045
I have a customer that has asked of a method of being texted should a fault occur during none working hours. They do galvanized dipping on a huge...
17
11,845
I'd like to install one to notify operators of production rates and error conditions. We have an HMI, but it's not easy to see from where the...
2,243
Hi, We are looking at getting some full bottle label inspection equipment in the factory where I work. We currently use Mapex and they are quite...
7,853
Can anyone recommend a simple Barcode Scanner? I will be using port 2 of AD 260 CPU and I only need to scan a 7 digits Barcode number into...
7,724
