90/30 Floating Point Error
UKB
Aug 2014
UK
56
Hello,
I am doing some floating point maths in a GE 90-30 PLC with a 374 CPU
When I view a register set up as a floating point register I cannot enter the value I intend.
Example.
Write a value of "4.8" to register %R0131
When I view %R0131 the PLC displays "4.8000001907"
Can anybody explain this?
I need to check an axis actual travel position, and to compare it to the master travel position. To do this I have to multiply the axis travel...
2,559
We have AOIs for projects, which handle material dosing (by hand or by pipes and pumps), obviously they have comparison between setpoint and...
50
14,196
Hi eveyone. I need transfer signal from system 1 to DCS via modbus. System 1 only can send 32 bit floating point. DCS receive 16 bit integer. How...
20
10,564
Hi, In my ladder logic, I've got a data register D60 whose value is -0.001 (when using monitor mode to see values). D406 is 0.250. But then...
1,300
Hi, can anybody tell that how can we move floating point data from one Regiter to another register in Fatek PLC.?
1,546
