plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 15th, 2019, 04:15 PM   #16
jraef
United States
jraef is offline
jraef's Avatar
So were you in V/Hz mode prior to that?
Did you perform an Autotune?
Old May 15th, 2019, 05:02 PM   #17
Stankdaddy
United States
Stankdaddy is offline
Correct, we were in V/Hz mode prior. He put it in SVC mode and immediately the symptom went away. Unfortunately some other issues in my plant needed my attention so I'm not sure if an Autotune was performed post change.
Old May 15th, 2019, 07:07 PM   #18
jraef
United States
jraef is offline
jraef's Avatar
On the 525 (all all Gen 4 IIGBT based drives) even if you use V/Hz, it's a good idea to do the Autotune if you want any reasonable accuracy.
Old May 16th, 2019, 09:21 AM   #19
Firejo
United States
Firejo is offline
Firejo's Avatar
My 2 cents.
I would implement a discrete start/stop signal or via comms to the drive and not rely strictly on the 4-20ma signal. While I do recognize the "sleep/wake" mode will deal with the lack of resolution effecting the low signal level (4mA) if you get a surge on the analog signal you could get a jump in the drive. If the discrete input is off then it won't matter what the analog signal is at, the drive won't start. Having said that I'm not a "drives" expert so I don't know what standard practice is but I use drives a lot in demo displays and if I had to deploy one in an application I would feel much more comfortable having a digital signal control the start/stop with the analog controlling the speed.
Again, just my two cents.
__________________
Go Hawks!!!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
DOL chnaged to PowerFlex 525 Issue lanester LIVE PLC Questions And Answers 3 March 28th, 2017 12:25 PM
PowerFlex 525 - Lobe Pump Flow PID Control freju LIVE PLC Questions And Answers 7 February 7th, 2017 08:55 AM
Simple way to program a lot of drilled holes?? neilfl LIVE PLC Questions And Answers 103 March 20th, 2012 10:23 AM
Help Rodter LIVE PLC Questions And Answers 18 April 24th, 2006 05:37 PM
how do I 'queue' machines using PLC & relays hickman LIVE PLC Questions And Answers 42 September 2nd, 2003 09:16 PM
