IXON IXrouter and CompactLogix
Timer
Aug 2017
Germany
26
Hello people.
Need some advise with remote PLC access.
The client wants to get some tags' values to his phone. In previous projects there were SIEMENS PLCs with IXON IXrouter connected.
Is it possible to use IXON with CompactLogix? I checked at IXON site, there is no AB in the supported PLC list.
If this is not possible - is there any other solution?
Thanx in advance.
Never heard of that device, but the support site lists AB PLCs and Ethernet I/P as supported.
So a qualified maybe, worth calling them and asking I suppose.
You're right, I missed this one. I'll try to check it tomorrow.
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
95
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
98
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
113
Hello all, and thank you in advance for any assistance you may be able to provide! This is my first post, so if I need to reformat or change...
477
We are trying to poll data coming from a PLC for remote monitoring we have the IP address of the PLC and the default port number and the path is...
25
572
