Microsoft ADO Data Control 6.0 Does Not Connect to My SQL???
Gabriel B. C.
Oct 2017
Porto Alegre
57
Can someone help me because my Adodc is not communicating to my SQL pack?
1 - My factorytalk 8.0 when I fetched the Object - Active Control - Microsoft ADO Data Control 6.0 - gave me an error - License to install this I installed Microsoft Studio Visual Basic 6.0
2 - Done This I searched again for my Microsoft ADO Data Control 6.0 and my DataGrid.
I do all his configuration looking for the Bank to squeeze table in Test as if it had everything ok.
Does anyone know what may be happening that I can not connect it to my SQL?
I think you need to create a recordset
So Dim rs As New adodb.Recordset
Set rs = New adodb.Recordset \\Set it as a record set
then
Set DataGrid1.DataSource = rs
DataGrid1.Refresh \\Refresh the dataset
MyDBCon.Close \\ remember to close the connection
Not this way I can connect Microsoft ADO Data Control 6.0 to my SQL database and you saw it all Ok communication!
When I put the wheel in it doesn't get the black arrows. I feel like I haven't connected to anything.
I've arranged my script as you said but without success. I don't know what to do anymore. I need a grid showing my sql information on my FactoryTalk process screen.
Any other suggestions friend?
The problem we have is that a SERVER 2016 RDS HOST machine will not change the path to read the new SERVER2016 RDS LICENSE server. Instead, it...
1,569
Does anybody use for remote tech support? Quick Assist, QA, comes with Windows 10 and 11 so it is "free" QA uses HTTPS for security but I wonder...
1,386
I have been playing w/ my Microsoft 365 account. Found this as I was looking for Visio. Apparently there is this form app. I just started one...
1,062
I'm wondering what people do these day when Excel is needed on an offline computer. Look at Microsoft Store's link, it seems it does require...
2,569
I'm building a FT View SE Network Distributed application on Microsoft Windows Server 2016 Datacenter. Original application was FT View SE v8.2...
2,364
