Panelview Plus 7 software stopped responding
Gadelric
Nov 2018
Midwest
137
Wizards,
I have been farmed out to another plant because they are having all kinds of issues. Most of the items I have been able to correct, but I have a bunch of Panelview Plus 7s that reboot quite often and display Error #2 Application stopped respond. I get the options to just reboot, which it does after about 10 seconds or a safe mode boot. I found a forum post on a different website from back in 2013 about this same issue, but no one provided a solution, Any ideas?
Current firmware is V9, and these are brand new machines that got delivered to this facility.
I suggest resetting the Panel back to default settings. Then re download the project to the panel. See the Panelview Plus 7 user manual for instructions on resetting the terminal.
Update:
Turns out the wizard that wrote the HMI, in their infinite wisdom, decided to use a macro becuase they made all the screens pop ups, not replace. So the macro was crashing the program.
Good afternoon all, I have the above HMI from AB with firmware v9, with the program created by an OEM. Their laptop is using view Studio v9 as...
2,273
Trying to figure out what software is needed to program an Allen Bradley HMI 2711P-RDT-10-C I have FT View Studio for ME EN (9701-VWSTMENE) Will...
3,909
Dear Friends, I want to connect a Controllogix 5563 and a PanelView Plus 1250 (2711P-T12C4D8). My questions are: 1)How many types of cable (and...
3,326
I need to know what software I need to program a 1250 Plus planel view. I have access to PanelBuilder 32 ver 3.82.01, will I be able to use this?
1,608
I have a problem with a panelview plus 400, the unit is connected via ethernet to a switch, then to a compactlogix plc. Recently this has stopped...
8,513
