PLC question - delay outputs
muzikant5
Mar 2009
toronto
17
Hi
I'm new to this forum. I'm trying to write a simple program that will do the following.
Turn ON Output 1
Delay (this delay should be adjustable)
Turn ON Output 2
Turn OFF Output 2
Turn OFF Output 1
and the process repeats itself
I know it's might sounds simple to some of you experts but I'm just beginning to program with PLC and I'm having a hard time doing this. Thanks for your help in advance guys.
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
79
I've ready through the the previous posts, and we've worked with safety design for a long time. In the past, we worked with Pilz directly, and...
563
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
766
I know this can be done, but I can't get the router config right. My goal is to physically connect(using an ethernet cable) a device(PLC, RTU...
1,019
Hello. Was just curious, if it is possible to load an image from an SD card on to a Compactlogix PLC that came straight out of the box brand new...
545
