plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old June 28th, 2020, 07:08 PM   #1
Baker in Virginia
United States
Baker in Virginia is offline
Panelview Plus-What is the best way to get back into Config Mode ?
Good Evening ,
I have a Panelview Plus that I need to go back into Config Mode. I understand that if you have a USB keyboard you can press the Default button and go into a screen that will allow you to go into config mode . Is that safe and easy to do ?
At one time wasn't there a white box you could press on bootup ?
Thanks so much for your help.
Old June 28th, 2020, 07:23 PM   #2
ASF
Australia
ASF is offline
Many versions have the white square at bootup. I'm not sure which version first introduced it. Then there was one minor revision (somewhere around v6, IIRC) where they removed it, and following an immediate uproar, reintroduced it in the next minor revision.
Next bet is a USB keyboard and Ctrl+Alt+Shift+Windows
There are other ways in as well, but 99% of the time, those two will get you by.
Old June 28th, 2020, 07:25 PM   #3
chavak
Malaysia
chavak is offline
chavak's Avatar
I understand you can go to config mode using a USB keyboard.
But in my opinion, the best thing to do is put a 'Go to Config Mode' button in one of your screen, maybe with password protected.
But I guess now you have to upload the runtime file, add in the above button and download it back.
Old June 28th, 2020, 07:36 PM   #4
Baker in Virginia
United States
Nobody knows the password . Once I make some modifications to the application I will add a go to configure mode button .
Old June 28th, 2020, 11:03 PM   #5
Mike Lamond
United States
Mike Lamond is offline
Can you connect to the PanelView with a VNC client? Use the "Send Ctrl-Alt-Del" button will cause the Windows CE OS to bring up the standard dialog box with the Restart Windows option. Win CE will restart to the desktop and when you start the PanelView Plus runtime it will go into config mode instead of running the application. At least, that's my experience with PV Plus 7 Performance.
Mike
Old June 30th, 2020, 12:20 PM   #6
Jsu0234m
Supporting Member
United States
Jsu0234m is offline
The best way would be to put a go to configure screen button in your HMI program, either hidden behind something that would never be touched or locked behind a login screen.
If you forgot to do this and the little white square isn't there on reboots. Then you will need to either reset the panel view with the buttons on the back or plug a keyboard in and press Shift-Ctrl-Windows-Alt all at the same time until the end program screen pops up.
The keyboard method takes a few tries but it usually works.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Beckhoff CX9000 Stuck in Config Mode avalancheroy33 LIVE PLC Questions And Answers 4 June 22nd, 2015 07:56 PM
Panelview Plus 1000 config download NetNathan LIVE PLC Questions And Answers 13 February 3rd, 2014 09:53 PM
How can i restart my panelview plus 600 in safe mode? rafaelrio LIVE PLC Questions And Answers 2 July 1st, 2009 06:51 AM
Panelview Plus 600 reading from SLC5/03 via NET-ENI story... Jawmunji LIVE PLC Questions And Answers 4 June 20th, 2007 12:30 PM
ControlLogix and PanelView RIO automfg LIVE PLC Questions And Answers 1 August 11th, 2006 03:30 AM
