plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old June 30th, 2020, 04:51 PM   #16
Kroger2013
United States
Kroger2013 is offline
As requested. The runtime looks different due to me adding them manually as suggested by Rockwell Technical Support.
Old June 30th, 2020, 05:21 PM   #17
_Dock_
United States
_Dock_ is offline
When you put the non working version in the HMi, can you ping it from your network with your PC?
Are you keeping the frimware the same or changing it each time you revert back? I don’t believe a firmware change Will wipe the IP address on the hmi, but it is Rockwell, anything is possible.
Sometimes it’s the easy things. Maybe try to see it in linx as well?
Old June 30th, 2020, 05:23 PM   #18
Kroger2013
United States
I can see the processor, I can ping it and I can see the HMI establish two CIP connections to the processor.
Old June 30th, 2020, 05:41 PM   #19
_Dock_
United States
_Dock_ is offline
Are you using the ME transfer utility? If so do you have “replace communications” checkbox selected when doing the transfer?
Old June 30th, 2020, 06:24 PM   #20
Kroger2013
United States
Quote:
yes
Old June 30th, 2020, 09:12 PM   #21
_Dock_
United States
_Dock_ is offline
Well, all the basics seem to be covered. You are concerned with the node limit. If possible have you tried removing a few devices to see if the problem resolves itself? The only clear path of consistency I can see is that your colleagues have the same issue, that would say hardware issue to me.
I’m sure you’ve considered these things. I just don’t know what else to offer you to help. If not a hardware problem, then this is deep in software somewhere that is probably a perfect storm to your application.
Judging by the lack of responses by people on this website that are way smarter than me I would guess they are stumped as well.
Old June 30th, 2020, 09:14 PM   #22
_Dock_
United States
_Dock_ is offline
With the new revamp to the knowledge base it is mostly useless. I looked through some of the articles and nothing seemed to apply to your problem.
Old June 30th, 2020, 09:20 PM   #23
Kroger2013
United States
Agreed. I gave up on it for the day. I have made sure I was down to 28 CIP connections out of 32 being used when I put the rev 10 HMI in place. Still, no luck.
Old July 1st, 2020, 07:44 AM   #24
Jmeadows7676
United States
Jmeadows7676 is offline
You could make a test project just to see where the problem is. Create a New Project talking to those PLCs if it works then something is up with the Conversion from 6 to 10.
Old July 1st, 2020, 08:30 AM   #25
Kroger2013
United States
Quote:
I will try that today. Thanks.
Old July 1st, 2020, 09:47 AM   #26
Operaghost
United States
Operaghost is offline
Operaghost's Avatar
The Communications Setup can contain devices that no longer exist. As you connect to networks it will discover devices. Then if you connect on a different network those devices are "hidden". So it maintains a sort of history of devices. On the Ethernet driver there is an option to Show All Devices. Deleting shortcuts does not delete this "history".
What I would try next, is to delete the RSLinx Enterprise (or the new name: FactoryTalk Link) server and then recreate it. Then recreate the shortcuts. This will wipe out all of the old stuff.
On another note, the Shortcut Verify button is useless. It does not verify the shortcut at all. It simply verifies that you have selected a device on the Local and the Runtime tabs, as well as checking for an offline tag file. It does not verify that the shortcut actually works.
OG
__________________
I despise when people take random quotes and ascribe them to me - Julius Caesar
Old July 1st, 2020, 09:57 AM   #27
Kroger2013
United States
OG
I did that under the runtime tab. I deleted all of the devices under the backplane as suggested by Rockwell Technical Support. It did not work.
Old July 1st, 2020, 10:13 AM   #28
Operaghost
United States
Operaghost's Avatar
No, I am saying to delete the server. Not the shortcuts or the hidden devices. Make it rebuild the comms server.
OG
__________________
Old July 1st, 2020, 10:44 AM   #29
Kroger2013
United States
OG
Are you talking about deleting the server under the Communications tab?
Old July 1st, 2020, 11:38 AM   #30
Operaghost
United States
Operaghost's Avatar
Right-click on RSLinx Enterprise/FactoryTalk Linx and delete it. You can add it back in the same way.
I would delete it and probably reboot the PC before I added it back.
OG
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
FTView ME Station Tags Issue Bbarnett LIVE PLC Questions And Answers 2 August 1st, 2019 02:15 PM
Studio 5000 v27 windows 10 J2009 LIVE PLC Questions And Answers 19 February 28th, 2019 01:47 PM
L35E Serial Comm OK, Processor Not Showing karlsigl LIVE PLC Questions And Answers 29 November 8th, 2014 05:59 AM
Disappearing Trigger Labels - FTView Studio JonHopper LIVE PLC Questions And Answers 0 October 29th, 2014 11:54 AM
Ton Timer ICAPALDO LIVE PLC Questions And Answers 41 December 21st, 2004 05:43 PM
