plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old June 29th, 2020, 07:47 AM   #1
Sergihno
Ukraine
Sergihno is offline
Book How to change Constant with address in CASE loop TIA Portal 15.1
Hello everyone,
Who knows how to implement constants in CASE loop via address to do it flexible. I show it on screenshot. Thanks a lot.
Old June 29th, 2020, 08:01 AM   #2
parky
United Kingdom
parky is offline
parky's Avatar
I don't think you can, the only way is to use if, else. endif statements not pretty but will work.
IF #MyTag== #CompTag THEN
.....Do something
ELSE IF #MyTag == #CompTag THEN
.....Do something
......Do something
ELSE
........Do something
END_IF;
Old June 29th, 2020, 08:18 AM   #3
CommissioningMan
Denmark
CommissioningMan is offline
Something like this?:
__________________
All things Siemens and Beckhoff. Please let it be Beckhoff.
Old June 29th, 2020, 05:27 PM   #4
L D[AR2,P#0.0]
United Kingdom
L D[AR2,P#0.0] is offline
Copy your but1_x vars to an array and then your posted code reduces to one line of SCL:
__________________
S7-300 to 1500 conversions done - email to s7conversions@hotmail.com
Old June 30th, 2020, 01:17 PM   #5
Sergihno
Ukraine
Sergihno is offline
Quote:
Attachment 54883
thanks a lot.
Is it possible to rewrite those STEPs from outside, from program?
Old June 30th, 2020, 03:17 PM   #6
L D[AR2,P#0.0]
United Kingdom
No, not with a case statement. Why don't you describe the actual processing you want to achieve - then we can suggest how to implement it.
__________________
Old June 30th, 2020, 05:02 PM   #7
L D[AR2,P#0.0]
United Kingdom
Here's an example implementation that allows you to use variables to control the case statement selections. I created an array of cases each containing an array of selections. You fill in the selections you want for each case - see my example code. The selections are set to -1 for an unused selection.
Code:
FOR #i := 0 TO 15 DO
    FOR #j := 0 TO 15 DO
        "dbVariableCases".VariableCases.Cases[#i].RangeSelection[#j] := -1;
    END_FOR;
END_FOR;
//testing code
IF false THEN
    //set up case statement selections example 1
    //case Index of
    //  0,1,2: "Tag_7":= "but1_1";
    //  3,4,5: "Tag_7":= "but1_2";
    //  6:     "Tag_7":= "but1_3";
    "dbVariableCases".VariableCases.Cases[0].RangeSelection[0] := 0;
    "dbVariableCases".VariableCases.Cases[0].RangeSelection[1] := 1;
    "dbVariableCases".VariableCases.Cases[0].RangeSelection[2] := 2;
    "dbVariableCases".VariableCases.Cases[1].RangeSelection[0] := 3;
    "dbVariableCases".VariableCases.Cases[1].RangeSelection[1] := 4;
    "dbVariableCases".VariableCases.Cases[1].RangeSelection[2] := 5;
    "dbVariableCases".VariableCases.Cases[2].RangeSelection[0] := 6;
END_IF;
IF true THEN
//set up case statement selections example 2
//case Index of
//  0,1,2,3,4,5,6,7,8,9: "Tag_7":= "but1_1";
//  10,11,12:            "Tag_7":= "but1_2";
//  13,14,15:            "Tag_7":= "but1_3";
"dbVariableCases".VariableCases.Cases[0].RangeSelection[3] := 3;
"dbVariableCases".VariableCases.Cases[0].RangeSelection[4] := 4;
"dbVariableCases".VariableCases.Cases[0].RangeSelection[5] := 5;
"dbVariableCases".VariableCases.Cases[0].RangeSelection[6] := 6;
"dbVariableCases".VariableCases.Cases[0].RangeSelection[7] := 7;
"dbVariableCases".VariableCases.Cases[0].RangeSelection[8] := 8;
"dbVariableCases".VariableCases.Cases[0].RangeSelection[9] := 9;
"dbVariableCases".VariableCases.Cases[1].RangeSelection[0] := 10;
"dbVariableCases".VariableCases.Cases[1].RangeSelection[1] := 11;
"dbVariableCases".VariableCases.Cases[1].RangeSelection[2] := 12;
"dbVariableCases".VariableCases.Cases[2].RangeSelection[0] := 13;
"dbVariableCases".VariableCases.Cases[2].RangeSelection[1] := 14;
"dbVariableCases".VariableCases.Cases[2].RangeSelection[2] := 15;
END_IF;
//variable case selection
        IF "dbVariableCases".VariableCases.Cases[#i].RangeSelection[#j] <> -1 THEN
            #Caseindex := #i;
            CASE #Caseindex OF
                0:
                    "Tag_7" := "but1_1";
                1:
                    "Tag_7" := "but1_2";
                2:
                    "Tag_7" := "but1_3";
                    /// etc etc
            END_CASE;
        END_IF;
    END_FOR;
END_FOR;
__________________
Old June 30th, 2020, 07:15 PM   #8
Sergihno
Ukraine
Sergihno is offline
Quote:
I have to realize controlled lets say counter. We implement in 24 hours as 1 day exchange in sec, for example 1h = 3 [sec] , or it can be X [sec]. So I implemented in touch panel each hour as bit changing button, toggle button and according to where it is on , I activate output, it should be the same output during 24 hour sequence. I will below the buttons as control for counter which activate output:
So , I want to do that time of 3 sec = 1 hour flexible and put from touch panel.
Old July 1st, 2020, 02:13 AM   #9
TurpoUrpo
Finland
TurpoUrpo is offline
Can you try to rephrase, I have difficulties in understanding what is it you try to accomplish here.
Anyway, CASE is not meant to be used so that the choice would be flexible, I think "SWITCH" that is used in some other programming languages to do the same is more clear on what is it supposed to do.
Anyway. CASE has an input variable than can change the "case" to be executed, not make those cases variable.
Old July 1st, 2020, 03:00 AM   #10
L D[AR2,P#0.0]
United Kingdom
My interpretation as follows:
You have 24 1 hour time slots.
You can select each slot to be active or not.
For an active slot, you can chose how long Q4.1 comes on for.
__________________
Old July 1st, 2020, 02:59 PM   #11
Sergihno
Ukraine
Sergihno is offline
Yes, I have 1 day = 24 hours, we say 1hour = 1 sec in our intervals. Intervals should be changeable. So If I want my output worked for first 3 hours I push those toggle buttons, so I have bits from them. The task is to do that time - 3 sec flexible to change, for example to change from HMI, so it should be some register to choose. With case it is impossible. I wrote the code it is now , it is with case and time of course fixed.
Old July 1st, 2020, 03:00 PM   #12
Sergihno
Ukraine
Sergihno is offline
I use SIEMENS S1500, so I have chose , STL, SCL, FBD and LAD, thats all.
Old July 1st, 2020, 04:27 PM   #13
L D[AR2,P#0.0]
United Kingdom
Example implementation:
__________________
Old July 1st, 2020, 05:26 PM   #14
chelton
Australia
chelton is offline
I haven't worked with s7 but
Wouldn't #HourNow be "0" between midnight and 1am?
Old July 1st, 2020, 06:00 PM   #15
L D[AR2,P#0.0]
United Kingdom
Yes, good spot. Redeclare the arrays to be [0..23].
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
TIA Portal 15.1 Issues Lary LIVE PLC Questions And Answers 37 June 11th, 2020 12:11 PM
Issue Changing IP on TP700 (WinCC / TIA Portal v14) kdcui LIVE PLC Questions And Answers 8 October 8th, 2019 02:28 PM
Simatic S7 Classic or TIA Portal Abigail LIVE PLC Questions And Answers 11 April 9th, 2017 05:13 AM
Siemens OP77B Trouble in TIA Portal Tim James LIVE PLC Questions And Answers 4 December 24th, 2012 03:27 PM
DL-06 question..... David_Emmerich LIVE PLC Questions And Answers 4 September 11th, 2007 10:29 AM
