i don't know much about G5
possible to check this parameter and probably use as comparator.
That is interesting. I haven’t found that document yet and it is stating that the max and min is 5000%.
So within that 5000%, at 100% the motor should be at its rated torque.
I did call the actuator company and it turns out this actuator is a custom one. They are sending me the spec sheet on it.
Thank you for your help!
