RSLinx
Ptolemies
Apr 2017
Manila
I have a problem with RSLinx Lite Classic. When I connect to the PLC, i can see the PLC (CompactLogix), but cannot see any of the modules connected. Please help.
Is this a new PLC that you are setting up? Or trying to connect to an existing system.
What version firmware is on the PLC? Right click the PLC and select "Device Properties" and see what it says under "Revision".
I am trying to connect with an existing system. I have connected to it before, but today I was about to online edit when I noticed in RSLinx that one module is missing. Then I power cycled, and after that there are no modules shown in RSLinx, just the PLC.
As for the version, it's 18.011
but does the auto-configure pass no problem
Yes, it is successful.
can you get properties of the controller through RSLinx?
do the modules appear to be powered up?
Are all the tabs pushed over for the modules?
Yes, here are the properties:
https://www.dropbox.com/s/sv392ibym9x6q9s/1.png?dl=0
The analog output module and MVI69-PDPMV1 are the only ones with LED on. The others (DI & AI) are LED OFF.
The tabs at the back? Yes, they are pushed over. The system is still working before I power cycled. The problem started after power cycle.
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
180
Does Rockwell still offer reset codes for old school Master Disk floppy's? In a bind and need to reset the activation disk soon and to be pointed...
230
Anyone have issues with RSLinx being very slow to open. It sometimes will say "Checking Activation" at the bottom for what seems like an...
141
I need to support some old data collection that is running on Excel, but I need to get it running on LibreOffice. The following statement works...
82
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
153
