Quantum CPU Configuration Problem
kamit patel
Jun 2007
Vadodara
I have configured the Quantum series(Modicon)PLC with CPU: 140CPU43412A with the configuration as per attached file Qauntum Config-1.jpg & Qauntum Config-2.jpg.
If I change the segments from 3 to 7,the final Logic Editor & Segment Scheduler appears as shown in attached file Qauntum Config-3.jpg.
I transfered these changes to CPU & found that CRA module installed in I/O rack shows ERROR on module.
Can anyone pl. explain me :confused: what is the effect of changing the no. of segments in PLC Configuration even if there is no logic made in CPU?
Hi all, I have 2x 140-67160 CPUs, these works as HOT-STANDBY arragement. Will have HMI as well. But I need to add one device that uses MODBUS. So...
1,988
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
512
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,914
Hello All, we have one machine which having Modicon quantum PLC with CPU 140 CPU 651 50. I have plan to modify small changes in PLC program. Is...
2,173
Hi everyone. I'm brand new here. PLC / SCADA programmer for 10 years in hydro, mostly using Unity Pro, Vijeo Designer and Citect 7.10 and higher...
1,405
