Blowdown valve fail to close
shkoko2000
May 2011
cairo
296
Dear all,
I want your help in below issue:
I have blowdown valve on compressor skid and when i close it(energize solenoid)
Find valve take no action. I measure the voltage on plc terminal(DO) found 24v.but when i connect solenoid and measured from solenoid side (the other side of terminal block) found no voltage.uptill now i wondered from this case as i remove solenoid cable the 24 voltage returned back.i have allenbradely control logix and 1756-OB32 is the digital output card.i try to connect 24v direct, the solenoid is enegized normally. I want to know what is the problem...
Please verify the wiring of the output card of the PLC.
Ensure that the output surge value of the solenoid is not greater than 1A.
Regards,
Agree with Dirt, sounds like an overcurrent problem. The easy fix is to add a relay. Let the solenoid turn the relay on and off and supply power to the solenoid from a relay contact.
I currently need some assistance for a PLC project that I have. Currently I am taking a PLC course that hasn't been very fruitful, but have found...
2,810
Good morning, We've had an issue with a couple of servo valves and was wondering if anyone had seen anything similar. After a drop in pressure...
62
Hi, The hardware is: Click Plc model # CO-O1DD1-O HMI model # S3ML-R magnetic-inductive flow meter model # FMM100-1001. I will set the flow meter...
117
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
408
Hi Everyone, Thought I had it figured out but I came to the conclusion it would not work. Here is what I'm working with... 1769-L30ER Flow Meter...
24
686
