Ethernet cable alternative
shkoko2000
May 2011
cairo
296
Dear all,
Please i want an alternative to ethernet cable as i want to connect to ethernet domain (192.168.1.xxx) without cable through wireless.what is the device that can fulfil my requirements...
If you want to connect your PLC to your WiFi network (assuming your PLC has an Ethernet port) get on of these, and set it up in Bridge mode:
https://www.amazon.com/TP-Link-Wire...ncoding=UTF8&refRID=NHGQFZ98MHB6CE6Q4ATV&th=1
Make sure to turn off the router and DHCP functions, or it will cause problems on your existing WiFi network.
OT, I also bought:
https://www.amazon.com/HOMREE-Conve...TF8&qid=1504505863&sr=1-5&keywords=24v+to+usb
and it a nice cheap way to be wire free when onsite commissioning instead of knelt inside a cabinet or balancing your laptop on your knees. Small enough to keep in your bag too.
Hello, I've been trying to learn this a while now and still have not found out how this works. I have an Omron CJ2M PLC and an ABB ACS 355 VFD...
219
Hello Everyone, I was wondering if anyone has any suggesting on getting Ethernet Cables with RJ45 connectors into control panels. Looking for...
1,747
What is the symbol for a Ethernet cable on a Loop Diagram?
819
Hi, Dose anyone have recommendations for Ethernet cable for site-use with laptop? I usually use regular office cable, but the lock-pin usually...
3,893
Hi, expert: we have one machine with 6 Sercos axis (kinetix6000) controlled by L71, there are 1756-M08SE and 1756-EN2T and one input module and...
2,615
