FactoryTalk View Studio ME v9 Tag Browser Descriptions are Blank
Tanquen
Jul 2014
CA
163
Using the Tag Browser I can indeed browse the tags in the PLC but there are no descriptions. Even the screen caps in guide show the description column empty. Is there a setting in ME or RSLinx to include these? Is it disabled to speed up communications to the PLC?
The description column in Factory Talk View ME doesn't pull information from the PLC. It's just for you to enter descriptions in the ME software if the tag name doesn't describe what the tag is. More helpful for SLC based applications that use data table addresses instead of tag names.
If you need to have those descriptions populated with the descriptions in the PLC, the easiest way is export the tag database to an excel document (CSV). Do the same with your PLC tags. Open both documents and copy the descriptions for the PLC export into the HMI export. After you're done, import the HMI tag document back into your program and tell it to overwrite existing tags. This should populate the tags with the description, but you might want to back the program up to an .APA before you try it just in case.
There might be an easier way to do this, but I don't know of any.
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
123
Hi all, I'm having an issue with connecting View Studio emulation to a real PLC. I am running View Studio 8.01 on a Hyper-V virtual machine...
255
Hello. I have a Project I'm doing in Factorytalk View Studio. One of my displays I created has a bunch of red x's on all of the objects I created...
643
So, I'm new to the PLC world (fresh graduate) and at my job I've been pretty much only helping out the other programmers with simpler tasks while...
616
Good morning, I have a project coming up that will require my HMI runtime to toggle from English to Spanish via selector switch. What is the...
453
