WinCC 2008 - script for import/export recipes in CSV
italo2008
Feb 2009
Padova
95
Hi
I'm trying to import and export datasets of a project in CSV files, using a USB key. The OP is Siemens MP277. The user must be able to export a dataset to a CSV file in the USB key, and import the dataset from the usb key. I've written a script for export and another script for import datasets, this is the code
EXPORT (I have 3 recipes, and SmartTags("Recipe data.Recipe_Number") is the number of dataset I want to export/import
Code:
ExportDataRecords "Filling Gains",SmartTags("Recipe data.Recipe_Number"),"\Storage Card USB\ExportedRecipe\FillingGains.CSV",hmiOverwriteAlways,hmiOff,StateExportFillingGains
Do
Loop While (StateExportFillingGains <>4 And StateExportFillingGains <> 12)
ExportDataRecords "In_Flight",SmartTags("Recipe data.Recipe_Number"),"\Storage Card USB\ExportedRecipe\In_Flight.CSV",hmiOverwriteAlways,hmiOff,StateExportInFlights
Do
Loop While (StateExportInFlights <>4 And StateExportInFlights <> 12)
ExportDataRecords "Production recipe",SmartTags("Recipe data.Recipe_Number"),"\Storage Card USB\ExportedRecipe\Production recipe.CSV",hmiOverwriteAlways,hmiOff,StateExportProductionRecipe
Do
Loop While (StateExportProductionRecipe <>4 And StateExportProductionRecipe <> 12)
IMPORT
Code:
ImportDataRecords  "\Storage Card USB\ExportedRecipe\FillingGains.CSV",SmartTags("Recipe data.Recipe_Number"),hmiOverwriteAlways,hmiOff,StateImportFillingGains
Do
Loop While (StateImportFillingGains <>4 And StateImportFillingGains <> 12)
ImportDataRecords  "\Storage Card USB\ExportedRecipe\In_Flight.CSV",SmartTags("Recipe data.Recipe_Number"),hmiOverwriteAlways,hmiOff,StateImportInFlights
Do
Loop While (StateImportInFlights <>4 And StateImportInFlights <> 12)
ImportDataRecords  "\Storage Card USB\ExportedRecipe\Production recipe.CSV",SmartTags("Recipe data.Recipe_Number"),hmiOverwriteAlways,hmiOff,StateImportInFlights
Do
Loop While (StateImportProductionRecipe <>4 And StateImportProductionRecipe <> 12)
my problem is that the first script works (I find the 3 files in the usb key, with the correct values), but the second doesn't, and the value of variables Stateimport.... is 12 (error). could someone explain me where is the mistake?
Hi! I'm a little lost here. I have made a script in VB that run perfect when I simulate it on my programming machine (Windows 8.1) But when I...
2,782
hello all i would like to know is possiable to use script in manner to trigger bit something myself not so fimiliar on esp using script...
2,564
I have 4 arrays. 1. -> arrdb1 (array of 52 bytes) 2. -> arrdb2 (array of 20 bytes) 3. -> arr1db300 (array of 20 bytes) 4. -> arr2db300 (array of...
3,507
Hello, I am currently in the middle of a project and looking to read data from a .csv file on a server. I need to read this data and get it...
6,945
Hi all, I am trying to change the property of an object in the current screen. Changing the color of the object works fine but BLINKING property...
5,697
