hbenkaab.takeda
I created a program with 3 tags In1, In2 and Out (if In1 and In2 then out) and I downloaded it to my Emulogix 5868 (I'm using Studio 5000 logix designer V32 and Studio 5000 logix emulate) .
I created a display with "Studio 5000 View designer" and I added a Numeric display to show the value of the tag "Out".
Since I donc have an HMI I used the "emulator of the Studio 5000 View designer".
when I run the application the Numeric display become Red showing an error "BAN Controller Status Indicator Not Supported on Windows" "Enable to reach the controller emulate"
Which take me to my question is it possible to establish communication btw the Logix View Emulator and Emulogix 5868? I searched this information in the manual and I found that you can Set the path from the View 5000 Emulator to a virtual controller but when I tried it it doesn't work
It may look a simple question but until now I didn't found the answer. I added pictures to explain more my problem. thank you for your help I really appreciate it.
