Communication between Beckhoff RS232 and Schneider VSD (RJ45 Serial Modbus)
Profisaurus
Oct 2013
Cape Town
Hi Guys,
I have a Beckhoff CP6607. It has 2 ethernet ports, 2 usb ports, and a serial port.
I am trying to connect it to a Scheider VSD, an Altivar 71. The Scheider has a Modbus/CanOpen port, but if I plug it in to a switch it immediately trips the power. I then gleaned from the datasheet that the RJ45/ethernet port is actually a RJ45 RS485 serial port.
So basically I am trying to connect this RS485 serial port to the Beckhoffs serial port (which I assume is rs232).
Do I have to buy a converter, or is there some way that I can connect the VSD to the PLC over ethernet and just encapsulate this within another protocol?
I don't know for Beckhoff, but usually serial port on PLC is RS485. If not you can add RS485 port or use RS232 to RS485 converter. I would like to warn you to check documentation, and connect it properly as you have 10VDC on pin 7 (which you can use for converter).
For bridging modbus to Ethernet, Schneider recommends 174CEV30010, but you can also try Moxa NPort.
And at the end, to note that Altivar uses state machine, so if you want to start it you need little bit of programming.
Best regards,
Vuckovic Goran.
Best regards,
Vuckovic Goran.
Thanks Vuckovic, I managed to get communication.
I used a RS232 to RS485 converter. It worked first time.
I will take your other recommendations into account.
For the purposes of a project we want to display the UPS status (Phoenix Contact UPS-QUINT, part number: 2320267) in the program run in the IPC...
1,887
Hi, I've been struggling with this for the past two weeks now. As part of a bigger school project, I've been tasked with setting up several...
3,782
Dear Experts, Good day I have to make ethernet communication between S7-1200 ( 1215c) and Beckhoff PLC CX5010. My question here any expert can...
4,205
Hi everyone, I've got the following task - build a project for controlling digital outputs, and reading from digital inputs using a Beckhoff...
2,395
Hi everybody, An IPC connected to a Siemens PLC as a slave module. When I restart the PLC while IPC running then PLC can't find the IPC node on...
9,119
