Rockwell EMonitor CMS question
Mar 2015
Mariupol, Ukraine
71
Hello!
I want to build a condition monitoring system which will include one ConrolLogix 1756-L71 PAC, about fifty Dynamix 1444 Series modules (1444-DYN04-01RA) and a monitoring station with EMonitor CMS software (9309-CMS00ENE). I plan to collect all software (EMonitor CMS, SQL Server database, Studio5000, RSLinx etc.) on the same workstation. This workstation also will be used as a EMonitor client to analyze collected data.
But some moments are still not clear enough for me:
1. Is it possible to use all above mentioned software on a single stand alone station? Or we need to use separate computers for each task (CMS database server, CMS client, engineering station with Studio5000 etc)?
2. Does EMonitor CMS 4.0 installation package include Microsoft SQL Server software or we should buy it separately?
3. Does EMonitor CMS 4.0 support any Microsoft SQL Server's versions above 2012 (for example: 2016, 2017 etc)?
4. Does EMonitor CMS 4.0 include SQL Server User's CAL licenses?
5. Does EMonitor CMS 4.0 support Windows10 Professional x64?
Best regards, Oleksandr.
Emonitor CMS Platform compatibility
Good morning,
Emonitor CMS is compatible with most of the options you proposed.
Finally, do you developed the platform without problems?
If not, let me know.
Hi All, Just after opinions has anyone have experience of Emonitor Condition Maintenance Systems product ? Just considering it but cant seem to...
1,916
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
160
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
127
Hello, recently I saw a graphic from any Rockwell App, I cant identify which one is. Attached a SS. Its used to see dashboard from datapoints and...
127
I'm working with a project that contains some routines in ST but mostly in ladder. Am I correct in assuming this 'rung': DB1001DO._01AV55_OPEN :=...
114
