plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old September 21st, 2022, 02:52 PM   #1
arthur.hauer
Brazil
arthur.hauer is offline
arthur.hauer's Avatar
CPU313C+CP343-1 Communication lag while both OPC and HMI are accessing
Dear experts,
I have the following setup:
CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC HMI (not sure what protocol it's using) and Kepware OPC server (TCP/IP) via RJ-45.
When both OPC and HMI are acessing data (1~2s window between two data access requests), the HMI interface gets really 'laggy', reaching up to 30~40s between bit switch command(push of an on-screen button, for example) and actual action. The same behaviour goes for OPC server, although, commands are not as delayed as on the HMI.
I've tried reserving more connection resources for PG communication to no avail. Also tried increasing max scan cycle load from communication (from 20% to 50%), also to no avail.
Scan time didn't change (~35ms) when both were connected.
On CP 343-1 configurations, both ports are set to 'automatic setting'.
I've also observed the same behaviour when monitoring DBs.
Does anyone have any solution for this problem (or, at least, an explanation for why it happens)?
Att.,
Arthur
Old September 22nd, 2022, 03:12 AM   #2
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
All the data has to pass over the backplane of the S7-300 which is the slow MPI bus @187.5kbps.
The combination of the HMI and OPC reads or writes too much data too often.
That the PLC has 35 ms scan time also tells us that the CPU is at the limit. That does not help either.
Proper remedy is to use a CPU that is suited for the job. Either a 315-2PN/DP or a 317-2PN/DP. These are more powerful and has an integrated ethernet port that is much much more powerful than MPI.
A short term remedy is to modify the data.
The usual methods:
Cut out all data that is not really necessary.
Increase the update times generally.
Avoid 100ms.
Let the fastest be 500 ms, and chose greater if possible. Temperatures changes slowly, so these can be 10 s for example.
And group similar data together, dont read or write randomly.
__________________
Jesper
NOTICE:
JesperMP has passive-aggressive tendencies, can be impolite and may even use sarcasm !
Also: ᛁᚠ ᚢᚬᚢ ᚴᚬᚾ ᚱᛅᚬᛏ ᚦᛁᛋ ᚦᛅᚾ ᚢᚬᚢ ᚼᚬᚠᛅ ᚴᚬᛁᚾᛅᛏ ᛘᚢ ᚱᛅᛋᛒᛅᚴᛏ
Old September 22nd, 2022, 10:47 AM   #3
arthur.hauer
Brazil
The usual methods:
Avoid 100ms.
Jesper,
That was my first guess, but wanted a second opinion.
I honestly can't remember if I've already used an equal (or inferior) CPU in a similar arrangement.
One thing that got me scratching my head is the fact that we have S5s running smoothly with the 'OPC+HMI' setup (with an MPI to TCP/IP adapter).
Just for fun, a quick comparisson of response times between the mentioned CPU313 setup and a 1200 CPU (measured with Kepware OPC):
CPU313C - ~210ms
1200 - ~20ms
Thanks for the help!
Old September 22nd, 2022, 10:51 AM   #4
arthur.hauer
Brazil
The usual methods:
Avoid 100ms.
Oh, by the way:
your suggestions are completely valid, but, for our data access requirements, not enough...
I'll sugest a CPU upgrade.
Again, thanks for the help!
Old September 22nd, 2022, 01:59 PM   #5
Lare
Finland
Lare is offline
Quote:
Originally Posted by arthur.hauer View Post
Jesper,
Is tags updated also on S5s CPU as fast as tags are readed. I mean is there buffer on MPI adapter for tags and it looks fast on HMI but actually is slower as tags are readed from adapters buffer not directly from CPU tags.
Old September 22nd, 2022, 02:34 PM   #6
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Since you menation an MPI to TCP/IP adapter, you probably mean some kind of Profibus to TCP/IP adapter (*). MPI was newer supported on S5, but Profibus was. And a Profibus CP in an S5-115U or S5-135U rack can be reasonably fast.
*: or an adapter that supports but MPI and Profibus.
__________________
Jesper
NOTICE:
Old September 22nd, 2022, 03:40 PM   #7
arthur.hauer
Brazil
My mistake... You are correct.
It's a TCP/AS511 adapter (https://www.process-informatik.de/93...html/?lang=en_)
Old September 23rd, 2022, 04:50 AM   #8
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
That is an adapter for the S5 PG port, not MPI or DP.
In that case I am certain that Lare is correct, despite that the data seems to update fast, in reality is merely the data that is buffered in the adapter. The real data transfer is much much slower.
The PG port in an S5 PLC (with AS511 protocol) operates at 9600 baud (!).
So approximately 1/20 the bandwith of MPI @ 187.5 kbps, or 1/10000 the bandwidth of Ethenet @ 100 Mbps.
__________________
Jesper
NOTICE:
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Communication between ArchestrA IDE and OPC RSLinx server between different machines NathBarreiros LIVE PLC Questions And Answers 0 February 22nd, 2021 11:21 PM
Help require to configure OPC server to link two PLCs with an HMI AB2005 LIVE PLC Questions And Answers 4 July 16th, 2018 09:07 AM
Ideal S7-300 + OPC + HMI communication setup Clemenzo LIVE PLC Questions And Answers 7 January 13th, 2014 04:53 PM
MP 277 communication with RSLinx OPC Server arun_mallah LIVE PLC Questions And Answers 3 June 25th, 2009 05:32 AM
How can we use RS link Gateway as remote OPC server for Cimplicity HMI OPC client nitin.salvi LIVE PLC Questions And Answers 22 June 9th, 2009 05:46 PM
