Use Kinco HMI as modbus slave
nygma
Sep 2017
Budapest
Hi Experts,
I have a Kinco ET070 (or a Chinese copy) HMI with modbus. I want to find out if I can use this in an unusual scenario:
I want to access this device as a modbus slave. I mean I want to give it an station number and be able to read/write the internal registers as it would normally do the same with a PLC. Is this possible at all? I know where the RS485 settings are, but there is no station number for the HMI, only the PLC that I add to the layout.
I have a setup where a computer is running some bespoke code and it can talk to modbus slaves. I cannot make the computer itself as a modbus slave this is why I want to see if I can read/write the registers of the HMI over the modbus line.
Thanks a lot,
Csongor
According to the horrifying Kinco "HMI and PLC Setting" manual (and I hate to admit I've worked on these abominations) they can be set up as a modbus slave. The manual is included with HMIWare.
Sorry, this project has been on the backburner for a while. I am still not able to find the part of the document you are referring to. I can set up a project with a generic Modbus RTU PLC, I see how I can provide the slave ID to that device, but still not to the HMI.
Hi, Its possible communicate between kinco hmi (mt4404t) and Micro830 through a serial line ( rs232/485 ) ?
1,553
Can anyone help me getting this communications connection set up between KINCO GL100 and KINCO K508-40AR? I am using Port 1(RS485) on the KINCO...
3,297
Hi all. Are someone was tried to connect HMI with only serial port ( rs232/485 ) to a PLC (S7-1200 + CM 1241 RS485 ) I have a machine, where is a...
1,242
Does anybody have experience with the data logging on a Kinco HMI? I'm currently trying to log some dumb data. I have already created the DB and...
1,078
good morning can anyone help me to connect kinco hmi with plc Siemens s7 1200 using tcp and can i have simple project for plc and hmi thank you...
2,416
