Any Way to View an Event or Failure Log of AB PLC5/60?
mbd0722
Aug 2003
Taunton, MA
Is there a way to view any type of event or failure log of AB PLC5/60s. I have two redundant PLC5/60s running in a hot standby mode. The system failed over from the primary to the redundant PLC and I would like to (a) view any indication as to why they failed over and to (b) periodically check the general health of the entire network. The PLC and SCADA software is Rockwell Automation RSLogix5 and RSView32. Thank You
There might be several different reasons for changeover. Have you observed that when it changed-over, the new secondary (Which was primary originally) PLc went into Fault? If so, then you can figure out by looking into its Last fault status register. However, it both are in Run mode (and no fault) but changed-over, then you need to look into your program whether there is anything written into the code which changes over the PLC's based on certain conditions (Like sometimes, people write to changeover based on time - might be to carry out maintenance like changing batteries)
This may be something obvious that I could learn if I sat down to understand the topic in detail with tutorials and manuals. But sometimes it's...
128
Hello, we have two PC with the FT SE local application and the same project. The one PC is wrong about alarm and event log. When I open the...
460
I have a issue with my alarm summary/banner where it losses connection to the Alarm Server. It's kind of weird because when I click on the server...
1,337
Hi, I am having some issues with FactoryTalk View SE (Local) Alarm and Event server. In my "active" alarm windows all alarms is shown correctly...
968
Hey guys, I am looking to add a way of logging FactoryTalk View ME current user and when the user trigger a boolean (HMI PB) w/ timestamp...
2,915
