plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 16th, 2019, 09:48 PM   #1
AutomationTechBrian
United States
AutomationTechBrian is offline
SLC Battery Light is on... Why program isn't lost after weekend (turned off)
I was at a customer's today and 2 of 3 SLC 5/03s had the Battery Light on. I showed it to the maintenance guy and asked him when the last time the panel was powered down for an extended period of time. He said last weekend! I don't understand why they don't loose the program. The PLC power is off when the panel is powered down. Does a SLC 5/03 have EEPROM, non-volatile memory that I don't know about? I thought it was all volatile memory. What am I missing? I see municipal water and waste water plants with the same situation. They said the BATT light was not relevant to their setup.
Old July 16th, 2019, 10:20 PM   #2
Mickey
United States
Mickey is online now
Mickey's Avatar
Your SLC5/03 can have an EEPROM (its an option) see PDF
Also... The battery lite on just means its low, it can still hold the program. Depends on how low.
Quote:
IMPORTANT The SLC 5/03, 5/04, and 5/05 processors have a capacitor that provides at least
30 minutes of battery back-up while the battery is disconnected. Data in RAM
is not lost if the battery is replaced within 30 minutes.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old July 16th, 2019, 10:35 PM   #3
Operaghost
United States
Operaghost is offline
Operaghost's Avatar
I have seen the capacitor hold the program for a full day.
Also, the battery light coming on means the battery has crossed a threshold. it doesn't mean it is fully depleted. It could still be functioning just at less than optimal capacity.
I used to tell people when that light comes on you may have up to two weeks before the battery fully dies.
So, EEPROM, capacitor, battery not dead yet. Three possibilities.
OG
Old July 17th, 2019, 12:11 PM   #4
James Mcquade
United States
James Mcquade is offline
the slc500 series has 2 methods of maintaining the program.
the primary method is the battery.
the secondary method is the internal capacitors on the plc card itself.
these are meant to hold the program long enough for you to turn the power off to the plc, remove the plc card, and replace the battery so you won't have to reload the program. I have known the caps to hold a test program for months.
please remember, this is not a guarantee they will work, so have the program backed up before killing the power or replacing the battery.
I had to have a 5/04 that lost its program everytime the power was lost.
the plc board went bad and the battery never saw the plc memory.
I had it repaired by teamsesco, its now on our stock room as a spare.
james
Old July 17th, 2019, 02:13 PM   #5
kwade
United States
kwade is offline
Quote:
james
teamsesco site doesn't work, did we overload it?
Thank you, James for the 'word-of-mouth' reference to a somewhat local repairshop!
FYI: I did find a crawl at https://web.archive.org/web/20190511....com/about-us/
Old July 17th, 2019, 03:15 PM   #6
RoTaTech
Canada
RoTaTech is offline
RoTaTech's Avatar
Battery low
If the battery is loose, you may lose the program with power off.
__________________
"Nice mirror!" said Tom reflectively.
Old July 17th, 2019, 03:53 PM   #7
James Mcquade
United States
you maybe right, the site is down.
www.teamsesco.com
call 1-800-48-SESCO
(336) 662-0646
NOTE - teamsesco is a vendor I use to get plc components repaired and I am not associated with them.
I's sure there are others out there.
james
Old July 17th, 2019, 04:11 PM   #8
Blue Fox
United Kingdom
Blue Fox is offline
I had a site do similar recently all the battery lights were on - was a mixture of ab and Siemens. They weren’t concerned as wasn’t causing them a problem. Went back to the site a few weeks later and they said they seemed to have lost some mods a previous employee had done on one of the plcs. I had a quick look and compared online prog with a back up I had taken on a previous visit and found online had the mods missing. It was an s7-300 with an eprom however the mods had only been saved to the volatile memory and not the emotion so they lost them. I had to copy over my backup. All the other plcs had the versions on the cards which were correct. Moral of the story - don’t rely on the EPROMs unless site it has the correct programs!
Old July 17th, 2019, 04:21 PM   #9
Operaghost
United States
Operaghost's Avatar
Here is a telling comment.....
Quote:
That makes it sound like they are using the EEPROPM. RA calls it a UVPROM.
OG
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
SLC 500 BASIC Program Invalid Header Error kevgtown LIVE PLC Questions And Answers 0 March 29th, 2013 07:41 AM
Need Help with 1746-BAS error bfore LIVE PLC Questions And Answers 9 May 19th, 2011 03:24 PM
Program lost hramos_ LIVE PLC Questions And Answers 0 January 28th, 2010 04:20 PM
S7 312 program lost after power failure Thim LIVE PLC Questions And Answers 2 January 4th, 2010 01:20 PM
SLC 500 lost program Sparky LIVE PLC Questions And Answers 5 September 11th, 2003 05:35 PM
